Joined: Nov 10, 2011 Posts: 789 Location: Lancashire, England
Posted: Sat Jan 21, 2012 7:34 am Post subject:
I will be adding more to this, so far it's basically MK2's circuit but with potentiometer control instead of light sensitive resistor control and switches on the 4051's binary control inputs.
The slacker melody generator acctually divides the initial frequency into a reverse harmonic series, a non-standard scale. So you can't play tunes based in the standard western scale but you can make new tunes with it!
P.S. You may recognise a small riff I was able to figure out _________________ As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Joined: May 18, 2010 Posts: 286 Location: Oak Park, IL
Posted: Sat Jan 21, 2012 8:17 am Post subject:
Pretty cool set up . I like the push buttons on the controller inputs; I might have to consider adding those to my 4051. That is, when I get the time to finish my lunetta rehouse ! _________________ Zontar Prevails!
Posted: Sat Jan 21, 2012 8:48 am Post subject:
Go for it! It's really easy to get the hang of playing it, to learn all you really need is the truth table and pinouts from a datasheet for the 4051 http://www.alldatasheet.com/datasheet-pdf/pdf/173652/UTC/4051.html (see page 5) _________________ As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Joined: Jun 09, 2009 Posts: 130 Location: Honolulu HI
Audio files: 48
Posted: Sat Jan 21, 2012 8:21 pm Post subject:
Those some reused cat-5 twisted pairs I see? Approved.
Incidentally, if you go with a vco, it's possible to get something quite playable using a four button "binary" keyboard (four momentary switches either going straight to voltage dividers or a cmos analog switch with the outputs of the voltage dividers going to a summing circuit). It requires some practice to get the hang of the chording system for progressing along notes but it's kind of neat to be able to play tunes without moving your hand.
Posted: Sun Jan 22, 2012 5:59 am Post subject:
I once raided a skip outside a computer shop which was closing down
A neat idea indeed I have worked on something similar which I will post in my weekend of weirdness thread; instead of four buttons I used four oscillators and an R2R ladder which controlled a VCO.
With four buttons though one could ass potentiometers to each to tune them to different notes
oh that reminds me, I have a half dead 555 synth I made which used a similar system; combinations of the four keys produced different notes as the frequency determining resistors were all in parallel.
Such a good idea that I had it several times myself _________________ As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Please support our site. If you click through and buy from our affiliate partners, we earn a small commission.
