Bit Shape
Posted: Thu Jan 19, 2012 3:11 pm Post subject:
TC-11 1.2 Update |
Any day now you should see the 1.2 update for TC-11 in your iPad's App Store. There were some big under-the-hood things that needed work, but it came together much faster than I expected. I'm happy to break the new features to you all here. There are two significant upgrades:
1 - Live Patch Preview
In the Patch view, you'll see a floating window that acts the same way as the Performance view. You can play while you edit parameters, change sequencer values, waveforms, the lot. Device motion works, so you can try out everything while you patch.
The Live Preview window can be moved anywhere on the screen, and snaps to the edges. When you want it out of the way, it docks to the right side of the view:
This is a *huge* improvement to patch editing. It should make the flow of creating a new patch much easier (and more fun)!
2 - Sequencer Rate as BPM
You can now view the rate of the Sequencer in beats per minute, with a multitude of subdivision rates. This should make the Rate parameter more accessible. You can still set it to Hz if that makes more sense for your patch.
There are some other small bug fixes and improvements, but I'm hoping that you all will enjoy these two upgrades. Let me know what you think! |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Thu Jan 19, 2012 3:34 pm Post subject:
Looking forward to this. That little performance window will be a bit help, I'm sure. _________________ --Howard
my music and other stuff |
Posted: Thu Jan 19, 2012 6:16 pm Post subject:
Great stuff! _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
DES
Audio files: 6
Joined: May 16, 2005 Posts: 8902 Location: Birmingham, England, UK
Posted: Fri Jan 20, 2012 12:33 pm Post subject:
Oh YES! _________________ ACHTUNG!
Posted: Sat Jan 21, 2012 2:10 pm Post subject:
v1.2 update is now available in the Appstore! _________________ ACHTUNG!
