Will the Saw Animator work with Rising Saw (Ramp) inputs?
Page 1 of 1 [2 Posts]
Tenine
PostPosted: Tue Jan 24, 2012 7:07 am    Post subject: Will the Saw Animator work with Rising Saw (Ramp) inputs? Reply with quote  Mark this post and the followings unread
Hi All,
I'd very much like to build one of these into an upcoming DIY VCO to allow phase-modulation of a set of outputs.
I just wondered if the Saw Animator operates as intended with Rising Saw ( /|/|/| ) waveforms, or does it require Falling Saw ( |\|\|\ ) waveforms?
Also, What is the operational range of the CV input, +/-5V?
At what voltage is the phase 0 degrees, at 0V?
How far can the phase be shifted in each direction, +/-180 degrees?
Thanks in advance!
yusynth
PostPosted: Tue Jan 24, 2012 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
It works with both types of saws, the required range is 10Vpp balanced around 0V (-5V/+5V). For the dependancy between CV and phase I have no idea, I never checked that.
Yves
