Nord Lead 3 Pitch Stick: how to activate it
Page 1 of 1 [2 Posts]
JyGius
PostPosted: Wed Jan 25, 2012 6:23 am    Post subject:  Nord Lead 3 Pitch Stick: how to activate it
Subject description: Nord Lead 3 Pitch Stick
Hi all.
I just bought a second hand NL3.
It's all fine but I can't use the pitch stick.
I set the Pitch Bend Range to 2 Up / 2 Down and in the Active Device I see the Pitch Stick LED on (as indicated in the manual at page 116)
Is the Pitch Stick broken? It doesn't work...
If I move it I feel it very stable (it's firmly and can vibe) but it doesn't produce any effect on the pitch. Likewise it doesn't produce any midi signal.
I'm a little bit worried...
Any idea? Broken?
Many thanks.
Best Regards.
Gius.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jan 26, 2012 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
It is possible there are some loose connections inside.
Open the hood and check all cables.
To open it read the first part of http://nm-archives.electro-music.com/020_NordLead2/Red_Lady/Index_bestanden/Red_Lady/115-230_vica_versa.htm
At http://nm-archives.electro-music.com/020_NordLead2/Red_Lady/Index_bestanden/Red_Lady/Weighted_part_2.htm half way there are some sketches where the screws are located.
Wout
