Clock divider:16th note trigger problem
nutoniom
PostPosted: Thu Jan 26, 2012 6:33 pm    Post subject: Clock divider:16th note trigger problem Reply with quote  Mark this post and the followings unread
Hello,
I have finally tested the clock divider with my friend's kit and we have a problem:when the KR-55's trig out is set to 16th note, the KR-55 starts one step behind and lags with consitency, it doesn't happen with 8th note, everything is perfect then.
Is this normal, could a value be changed at the input of the divider so it's more sensible to the signal ?
thanks for any pointers.
jf
beyond the atmosphere, there is no space, only time...
http://www.7161.com/css_artist.cfm?user=380
