  Twyndyllyngs Live Chez Mosc
Suggestion for Jürgen's forum
Page 1 of 1 [5 Posts]
jumunius
PostPosted: Mon Feb 06, 2012 11:20 pm    Post subject: Suggestion for Jürgen's forum Reply with quote  Mark this post and the followings unread
So my thus-far futile attempts to debug my first two JH projects has me thinking. What would be really helpful is some good test files to compare results against. With a lot of synth projects, build results seem easy enough to verify. You can scope the outputs of a VCO to see whether you are getting a good sine, square, tri, etc.
With fx like many of Jürgen's projects, the results are a little harder to quantify. In the two BBD projects I'm building (Triple Chorus and SOST Flanger) it's not clear what I'm listening for in some cases.
And now, of course, the master has left us, which further obscures things.
So what I would propose is that people who complete projects and feel like they have a solid build might do a great service to the rest of us by recording a test file, processing said test file using a few easily reproduceable settings, and then posting the results. Future builders can download the raw file, process it as described, and compare results with the "benchmark".
So if and when I finish my SOST Flanger, I might play a saw wave patch for 10 seconds, and then take that recording and process it with a variety of Manual, Resonance, etc settings, with 1 or 2 BBDs, All Pass Filtering, with this or that inverted, etc. Then post all of it with appropriate notes.
Granted there are an endless number of permutations, but just get enough to give a builder a sense of what each key feature "should" sound like. And if one feature is missed and needed down the line, a future builder could ask if someone could take the raw file and process it with switch x thrown, and then again, you'd have a common file producing an expected result.
Granted, I will happily do this myself if and when I complete the projects I'm working on now, or any of the future JH boards in my collection.
Just a thought. Anyone like the idea? Have additional suggestions? How and where to organize?
I realize people got along here without this for years, but then again, JH used to be very active in offering advice for debugging, which wasn't as true towards the end of his life.
-Jim
djs
PostPosted: Thu Feb 09, 2012 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
One thing that really helped me with my X0XB0X build was a reference voltage chart that showed what volts should be at most locations:
http://img836.imageshack.us/img836/8567/mainboardwithanaloguevo.png
Obviously this is alot of work, and voltages can be variable in certain sections of the board, but this helps for many issues. Also, for easily identifying where you can find power supply, data, and ground lines.
jumunius
PostPosted: Sat Feb 11, 2012 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, yeah, that would be handy as well. Would be worthwhile to map something like that out, since so many problems come down to the basics.
With some of this stuff, however, an added issue is that there is all this lore about the way that chips of different manufacture perform -- which CMOS chip, with which BBD, etc. And then it's hard to tell how it's SUPPOSED to sound. With a 303/808/909 there are a gazillion samples out there to inform you. With an effect, it's not so clear.
I'm thinking now that my SOST build may not be so far off.... if I get a little more confident I'll post some samples for future builders.
-Jim
haima
PostPosted: Sun Feb 19, 2012 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
seems like a good idea.
sometime i'll try and record some dry / wet demos of my subtle chorus and solina chorus....
i'm re-jigging my studio at the moment and both those units are packed away so it won't be for a little while.
jumunius
PostPosted: Tue Feb 21, 2012 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, I look forward to it. I've put my Solina build into my rack for now, but I hope to open it up again in a few months.
I don't know what the best approach is for this. For the Solina it's easy enough to use one of Jürgen's demos (the one I've been using in the Solina thread) as source material so one can compare his sound to your own. But then the source is MP3, so maybe that's a downside, fidelity-wise.
If you get around to it and want to start from your own source files, perhaps you can post the dry file in aif so others may use it easily for their own full-bandwidth comparisons.
-Jim
