BA3812L Rohm 5-Band Graphic EQ IC Help
Page 1 of 1 [2 Posts]
low_rider
PostPosted: Mon Feb 06, 2012 1:22 am    Post subject: BA3812L Rohm 5-Band Graphic EQ IC Help Reply with quote  Mark this post and the followings unread
I was looking into building a simple EQ using a ready-made IC that needs some external components. The datasheet is minimal with two formulas to calculate Q and freq. If I understand correctly, higher Q means a smaller bandwidth and more boost & cut and lower Q affects the other way around. What I would like to know is how to calc. the boost/cut (dB) according to the Q at a specific freq. ?
http://www.electroniq.net/audio/ba3812l-graphic-equalizer-circuit-diagram.html
Mongo1
PostPosted: Sat Feb 11, 2012 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I believe the maxiumum boost/cut is going to be constant. The Q really just affects the bandwidth.
It's odd that they don't specify the boost/cut involved, but most of these chips are generally set up for +/- 12db
Gary
JuneSolstice2013
