Control PW of 3 VCOs using one pot
Page 1 of 1 [4 Posts]
involver
PostPosted: Fri Feb 17, 2012 6:01 am    Post subject: Control PW of 3 VCOs using one pot Reply with quote  Mark this post and the followings unread
I am planning the front panel for my new synth. Due to space considerations I have decided to have one control for the pulse width of all three VCOs. (I will also have inputs for each VCO's PWM so I can control them separately with CVs).
I am using curetronic System 100m VCO's. There is an input for the PW pot on each board and also a PWM CV input. Full schematic is here:
http://www.curetronic.com/curetrbau/neubau/112m.htm
What is the best way to do this? Triple gang pots seem a bit difficult to find?
JovianPyx
Audio files: 123
PostPosted: Fri Feb 17, 2012 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Since each VCO will have it's own PWM CV input, you can add a summing amp to each PWM CV input so that each VCO actually has 2 PWM inputs. One PWM CV input from each VCO just gets a CV jack, the other receives a voltage fed to it by a single pot. Since by it's nature a summing amp inverts, each summing amp will have to be followed by an inverting unity gain amp. So two opamps are required for each input.
I wish that the schematic were labeled, since it is not is difficult to make a more in depth analysis.
HTH
FPGA Synth Stuff
FatMan Mods
dsPIC Synth Stuff
I am formerly known as ScottG here
Time flies like a banana.
3vcos
PostPosted: Fri Feb 17, 2012 7:46 pm    Post subject: Re: Control PW of 3 VCOs using one pot Reply with quote  Mark this post and the followings unread
No one controls me !!!!!!! Laughing
involver
PostPosted: Sat Feb 18, 2012 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Not even by CV or FM? Laughing
Niio1
