  Postponed until tomorrow. Sorry... Chez Mosc
Roland Kuit SoundLab II, Architectures for Philosophers
Page 2 of 3 [59 Posts]
iPassenger
G2 patch files: 78
PostPosted: Wed Jan 25, 2012 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Roland Kuit wrote:
But I will start easy for you.
Example: 2 NAND gates as 1 AND gate:
Am I right in thinking the second NAND is just working as a logic inverter?
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Wed Jan 25, 2012 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh so both AND switches would produce the same results?
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Wed Jan 25, 2012 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Roland Kuit wrote:
Logic switch Ring Oscillator:
With this one, could you not have just used a single invertor to produce the 12Khz signal?
iP (Ross)
Roland Kuit
G2 patch files: 127
PostPosted: Wed Jan 25, 2012 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
The answer is yes for both logic questions, great! A little fine tune: A logic NAND gate CAN work as an inverter.
In SoundLab II, everything is build up from the begin. I just placed here a few examples/riddles.
Remember, for ringing(FB), you need an uneven number of inverters.
Like before the ring, to find out tuning, I came up with this one.
So, combining this pch with the Logic Ring Osc, is getting things one step further.
But this is not my teaching page...buy the book! Wink :
iPassenger
G2 patch files: 78
PostPosted: Wed Jan 25, 2012 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Roland Kuit wrote:
But this is not my teaching page...buy the book! Laughing
Lol, ok. Smile
With regards to the inverters, at first i thought each one was stepping down the frequency but all they do is introduce another 1 sample delay and yes I worked out the odd number issue when messing with them at home...obvious really when you think about it but logic stuff is not obvious at face value, you have to work through it... or at least i do. Very Happy
iP (Ross)
Roland Kuit
G2 patch files: 127
PostPosted: Thu Jan 26, 2012 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Logic modules to define the formant. Cascading Flip-flop modules could be used:
cappy2112
PostPosted: Thu Jan 26, 2012 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is SLII ready?
Roland Kuit
G2 patch files: 127
PostPosted: Thu Jan 26, 2012 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Cappy. Nearly, a few small things to do and waiting for the cover. so it will be still April/May 2012.
Roland Kuit
G2 patch files: 127
PostPosted: Thu Feb 02, 2012 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unusal little sync thing:
Roland Kuit
G2 patch files: 127
PostPosted: Fri Feb 03, 2012 3:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Xor sync phasing:
Roland Kuit
G2 patch files: 127
PostPosted: Sun Feb 05, 2012 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Mashing up audio will be discussed too. What to think about 8 Notch filters you can modulate ending up in a phaser:
Roland Kuit
G2 patch files: 127
PostPosted: Wed Feb 08, 2012 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
An 8 cascading Flip-flop pattern melody:
Roland Kuit
G2 patch files: 127
PostPosted: Wed Feb 15, 2012 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
As I stated before, Audio processing will be discussed too.
From sweetness to heavy soundscapes.
In this case a Resonator Neuron model(just my vision):
Some G2Demo Resonator X audio examples:
1 soundscaping:
http://snd.sc/xRLyGz
and 1 with drums:
http://snd.sc/xs4RSJ
Roland Kuit
G2 patch files: 127
PostPosted: Thu Feb 16, 2012 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
A digi filter. 8 times minus 1 sample delays comming together in 8 static switch modules. By switching you change the coeffs:
http://snd.sc/AeVIOs
This one is static(by switches), but I've made some time changing too.
Roland Kuit
G2 patch files: 127
PostPosted: Sun Feb 19, 2012 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
An other Digi Filter:
http://snd.sc/yAi18X
Roland Kuit
G2 patch files: 127
PostPosted: Tue Feb 21, 2012 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Some other filter bashing.
Kick and snare drum into a coeff filter field with modulated Delay lines.
For audio example:
http://snd.sc/yYQ7wO
Roland Kuit
G2 patch files: 127
PostPosted: Sun Feb 26, 2012 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Granual BodeShift Sineblock oscillator:
Audio example:
http://snd.sc/xyHzgl
Roland Kuit
G2 patch files: 127
PostPosted: Tue Feb 28, 2012 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Funny but logic way to tune logic noise into octaves:
Audio:
http://snd.sc/wQzyYd
jima
PostPosted: Tue Feb 28, 2012 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I give up, I'll buy the book Smile
Regret I have been away for a while so unable to participate Sad
Jim
Roland Kuit
G2 patch files: 127
PostPosted: Tue Feb 28, 2012 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lol and glad you are back Very Happy
Roland Kuit
G2 patch files: 127
PostPosted: Fri Mar 02, 2012 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Logic swing fun:
http://snd.sc/zdZ43P
Roland Kuit
G2 patch files: 127
PostPosted: Sun Mar 04, 2012 4:19 am    Post subject:
Subject description: Sunday's riddle
Sunday's Logic Riddle:
Which 3 Logic modules + 1 control module has
to be filled in here to create this sound?
Audio example:
http://snd.sc/wM0YBG
Roland Kuit
G2 patch files: 127
PostPosted: Mon Mar 05, 2012 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Riddle part 2. Common guys, think Smile
Roland Kuit
G2 patch files: 127
PostPosted: Fri Mar 09, 2012 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
One of a bunch homebrew trigger sequencers, there are more complicated ones. For slower triggering, replace the 8Counter with the BinCounter.
Audio example:
http://snd.sc/zcuuzb
Roland Kuit
G2 patch files: 127
PostPosted: Mon Mar 12, 2012 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
PLL sync without syncing osc audio example:
http://soundcloud.com/roland-kuit/pll-without-syncing-oscillator
