Joined: Dec 11, 2010 Posts: 966 Location: Toronto, Ontario - Canada
Posted: Sat Mar 03, 2012 5:15 pm Post subject:
CMOS Wave Shaper Subject description: Schematic |
I am sure that there are similar schematics floating around the web and some people might have posted them here already, but I drew this up for myself and figured I would share it just in case someone else could use it.
The source sqaurewave could come from anything, but in my schematic it is a 40106 oscillator. It runs a little high and is used as the clock frequency for the shift register. The same signal is also divided with a 4040 and used as the base input for the shift register. I do this dividing so that the spacing of the steps changes along with the pitch.
I added a couple of option at the output for more shaping. A cap to ground rounds it off into a nice sine wave. Passing the sound through a low value cap acts as a highpass filter that turns each edge of the step into a spike.
You could probably do some really weird wave shaping by using separate low or highpass filters on each output from the 4006. This might almost allow you to draw the desired waveform with a bit of practice.
Description: |
Standard stepped triangle. |
Filesize: |
77.39 KB |
Viewed: |
48024 Time(s) |
Description: |
Filesize: |
80.38 KB |
Viewed: |
48024 Time(s) |
Description: |
Filesize: |
85.41 KB |
Viewed: |
48025 Time(s) |
Description: |
Filesize: |
25.96 KB |
Viewed: |
4439 Time(s) |
_________________ JacobWatters.com |
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Sun Mar 04, 2012 1:48 pm Post subject:
well, if this works, then its very interesting.
might breadboard it up tomorrow.
nice work _________________ _Richard_ |
Sodium
Posted: Sun Mar 04, 2012 1:56 pm Post subject:
Cynosure, that looks very nice, especially those spikes . Does it perform with other input signals as well, or is it square in only? |
sonic
Joined: Dec 02, 2010 Posts: 106 Location: Victoria BC
Posted: Sun Mar 04, 2012 2:10 pm Post subject:
This is very interesting indeed, Jake. I will try it out. It would be great to have an adjustable wave shaper module to accompany my 40106 VCO. |
Posted: Sun Mar 04, 2012 5:06 pm Post subject:
Sodium - It might work with other waveforms if the peaks go over the CMOS threshold, but I think for optimal performance you will want to use a comparator to create a squarewave if you are using a different wave as the source.
Sonic - I was actually thinking about your vco when I was making it. It would be a cool module.
I was playing around with it today adding more or less of the shift register outputs, and changing the mixing resistors for diodes or small caps. You can make some very unique waveforms, but it is kind of difficult to predict how it is going to look and sound until you test it out. _________________ JacobWatters.com |
sonic
Posted: Sun Mar 04, 2012 5:41 pm Post subject:
Cynosure wrote: | Sonic - I was actually thinking about your vco when I was making it. It would be a cool module. |
Wow! Thanks so much! |
JingleJoe
Posted: Mon Mar 05, 2012 3:11 am Post subject:
Isn't it easier to get that saw wave from an R2R ladder and a 4040? Acctually probably about the same effort/parts are required for each. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
Posted: Mon Mar 05, 2012 6:46 am Post subject:
JingleJoe wrote: | Isn't it easier to get that saw wave from an R2R ladder and a 4040? |
Maybe, but this is the idea I came up with. If you have another method, then please share.
I think it might be useful to put sliding pots on each output of the 4017 instead of fixed resistors. Then you could literally draw out any 10-bit waveform on the sliding pots.
Then add switchable highpass and lowpass filters to either smooth it out or make spikes. _________________ JacobWatters.com |
JingleJoe
Posted: Mon Mar 05, 2012 2:07 pm Post subject:
I've seen that once before used some different chips though if I remember rightly, you've come up with some good ideas here nevertheless I look forwards to hearing some of these circuits _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
concretedog
Posted: Tue Mar 06, 2012 6:51 am Post subject:
Cynosure...this looks brilliant...I didn't realise I hd any 4006 but just found one...will breadboard this when I get chance...that sine wave image has me tempted! |
Nardu
Joined: Feb 28, 2011 Posts: 62 Location: Braila, Romania
Posted: Wed Mar 07, 2012 5:59 am Post subject:
128 steps staircase generator ; an R/2R ladder network and a 4024 .
Description: |
Filesize: |
337.23 KB |
Viewed: |
1333 Time(s) |
Description: |
Filesize: |
345.64 KB |
Viewed: |
1180 Time(s) |
Posted: Wed Mar 07, 2012 11:19 am Post subject:
Wow Nardu! That is amazing. Thanks for sharing. _________________ JacobWatters.com |
Nardu
Posted: Wed Mar 07, 2012 2:13 pm Post subject:
4024 7b ramp oscillator stripboard (veroboard):
Description: |
Filesize: |
170.99 KB |
Viewed: |
826 Time(s) |
Description: |
Filesize: |
131.77 KB |
Viewed: |
829 Time(s) |
Posted: Wed Mar 07, 2012 2:21 pm Post subject:
Can I substitute different resistor values? 150k and 75k are odd values that i do not have in quantity.
Would 47k and 100k work? _________________ JacobWatters.com |
corex
Posted: Wed Mar 07, 2012 4:52 pm Post subject:
Cynosure wrote: | Can I substitute different resistor values? 150k and 75k are odd values that i do not have in quantity.
Would 47k and 100k work? |
The ratio is important: R/2R. 47K is half of 100K, minus 6%. With an error of 6%, your error term is as large as your fourth bit (1/16th == 0.0625, ~6%). That means that you may as well only build a three-bit R/2R ladder.
See https://en.wikipedia.org/wiki/Resistor_ladder#Accuracy_of_R-2R_resistor_ladders |
fluxmonkey
Posted: Wed Mar 07, 2012 6:07 pm Post subject:
but 47k and 94k (ie, 2 x 47k in series) would work...[/left] |
Nardu
Posted: Thu Mar 08, 2012 3:51 am Post subject:
Consider to use only 100k resistor. 2x100k in parallel = 50k.
Accuracy of R-2R resistor ladders for 7 bits is 1/127=0.79%
Discrete resistor should be 0.5% tolerance. |
Posted: Thu Mar 08, 2012 6:42 am Post subject:
Ok, so if I were to make it i would need to by resistors with better tolerance anyway, so i can get the same values.
Thanks! _________________ JacobWatters.com |
corex
Posted: Thu Mar 08, 2012 11:13 am Post subject:
Nardu wrote: | Consider to use only 100k resistor. 2x100k in parallel = 50k.
Yeah, this is the way to go. Especially easy if you've got a bin full of 100k 1%'s. |
JingleJoe
Posted: Thu Mar 08, 2012 1:10 pm Post subject:
For an R2R ladder, unless you want to be precise and accurate, almost any value will work. I think I used resistors near 220k and 100k in my Lunetta death pipes from outer space. I didn't have enough you see? So I just put in any near values. Everything still worked fine, things were just a bit non-linear. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Nardu
Posted: Thu Mar 08, 2012 2:00 pm Post subject:
An R/2R ladder resistor network ... it's about a simple precise and accurate D/A converter. |
dougseidel
Posted: Fri Mar 09, 2012 2:18 pm Post subject:
sometimes accurate and precise is either difficult to achieve, or just not as interesting. anyway, the ladder-shaped thing can be used to do all kinds of interesting translations of information. _________________ http://soundcloud.com/douglasmseidel |
corex
Posted: Mon Mar 12, 2012 5:23 pm Post subject:
dougseidel wrote: | sometimes accurate and precise is either difficult to achieve, or just not as interesting. anyway, the ladder-shaped thing can be used to do all kinds of interesting translations of information. |
This is an excellent point, especially regarding Lunettas. Imprecision is part of the fun. |
Draal
Joined: May 18, 2010 Posts: 308 Location: Oak Park, IL
Posted: Tue Mar 13, 2012 9:33 am Post subject:
Nice info . I approach the lunetta as a free form type of instrument, therefore precision isn't so important to me. I've done many versions of wave shapers, filters, adsr's, vco's and some of their complexity rivals that of modulars. Those machines rely on precise tolerances and ain't what I'm looking for in lunetta building.
Mosc clued many of us "in" long ago in reiterating the importance of keeping it simple with these circuits. Go ahead and make complicated modules but keep in mind they may not work the way you hoped. That is the Tao of Lunetta
But by all means experiment; us ol timers enjoy the newly initiated and their zeal . _________________ Zontar Prevails! |
