 Forum index » DIY Hardware and Software » Supercollider
Compiling Supercollider 3.5 on Ubuntu Precise
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [5 Posts]
kijjaz
PostPosted: Wed Mar 07, 2012 5:12 am    Post subject: Compiling Supercollider 3.5 on Ubuntu Precise
Subject description: Compiling & Making it works with gedit 3 support
( I firstly posted it on http://kijjaz.net/?p=174 )
Get the source. Now Supercollider's source at sourceforge.net is at version 3.5-rc3
http://sourceforge.net/projects/supercollider/files/Source
Prepare required packages:
Add this PPA repository: https://launchpad.net/~supercollider/+archive/ppa
or use command
$ sudo add-apt-repository ppa:supercollider/ppa && sudo apt-get update
Then...
$ sudo apt-get build-dep supercollider
$ sudo apt-get install cmake libcurl4-openssl-dev emacs libqt4-dev
Unpack the source package.
Compile:
$ cmake -DSC_ED=on
$ make
$ sudo make install
Since supercollider source code was designed to support gedit 2, in Ubuntu Precise running gedit 3, we have to copy or symlink two files for the plugin to work in gedit:
$ mkdir ~/.local/share/gedit
$ mkdir ~/.local/share/gedit/plugins
$ cp /usr/local/lib/gedit/plugins/supercollider.* ~/.local/share/gedit/plugins
Trying in out:
$ sclang
sclang: error while loading shared libraries: libscsynth.so.1: cannot open shared object file: No such file or directory
So now I will cheat a bit ... :
$ sudo cp /usr/local/lib/libscsynth.so.1 /usr/lib
Open gedit --> (menu) Edit --> Preferences --> (Tab) Plugins --> check at SuperCollider.
NOW I'M READY TO ROCK!
audiodef
Audio files: 53
PostPosted: Wed Mar 07, 2012 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I had the same libscsynth problem. Since I have no plans to use Wii or bluetooth, I ran ./configure -DSC_WII=off and that took care of it.
There's an invisible radio gnome playing a gong from a flying teapot - don't miss out!
kijjaz
PostPosted: Thu Mar 08, 2012 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
(edited: must add Supercollider PPA before apt-get build-dep supercollider)
kijjaz
PostPosted: Sun Mar 18, 2012 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
and now SuperCollider 3.5 is released!
http://sourceforge.net/projects/supercollider/files/Source/3.5.0
audiodef
Audio files: 53
PostPosted: Tue Mar 20, 2012 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the update. Cool
