Water & Bird Box
Page 1 of 1 [10 Posts]
jean bender
PostPosted: Sun Feb 19, 2012 4:08 am    Post subject: Water & Bird Box
Subject description: one year child gift !!
Hi all !
I want to share with you this little noise box i made for my friend's child birthday (one year !!). It gives a messy sound, but can create beautiful artefacts...
Here's the schematic ! I had best results with very little caps ( 0,001uf & 0,047 for the clock).
It's based on a cd4093 & a cd4094 ( i don't really know if i used it the right way...).
Let me know what you think about it, and ideas to improve it are welcomed !!
 Filesize:  11.98 KB
 Viewed:  131 Time(s)
 Filesize:  82.91 KB
 Viewed:  92 Time(s)
http://h.a.k.free.fr/
www.electroncanon.org
JingleJoe
PostPosted: Sun Feb 19, 2012 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Just looked up the 4049N but it appears you are using something else entirely, the only 4049 I can see is some logic buffers.
Would it be possible to get some sound too?
Psyingo
PostPosted: Sun Feb 19, 2012 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
4094.
jean bender
PostPosted: Sun Feb 19, 2012 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
i don't really understand what you mean Jingle jOe... sorry.... Embarassed
no sounds, it was a gift... But with very fast oscillators, you can get some sounds which can remind the eric archer tune in tokyo ( even if it's really not the same thing and not so complicated.... Wink )
brock
PostPosted: Sun Feb 19, 2012 5:21 pm    Post subject: Re: Water & Bird Box
There's a wrong way to use a part in a Lunetta? I think that if it makes sound, you've found a right way.
JingleJoe
PostPosted: Mon Feb 20, 2012 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
oh Rolling Eyes I read the number wrong on the IC, but I also requested some audio samples of this device.
PostPosted: Mon Feb 20, 2012 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I would have liked to hear it too. I am intrigued by electronic "water sounds", but right now I don't have a 4094 to build the circuit myself. Ah well, not sure when I can get to the electronics store... maybe I'll pick up a bunch of CMOS I still don't have.
jean bender
PostPosted: Sun Feb 26, 2012 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry, i don't have any sound sample... it's now in my friend's child hands... As soon as i get a recorder, i'll do that !! Razz
PostPosted: Wed Mar 07, 2012 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I finally managed to get to the electronics store and buy a 4094. I built the circuit, but instead of photo-resistors, I used pots. The sound was barely audible, so I just used one of the outputs of the 4094, bypassing the diodes & LEDs. All the outputs had the same sound, as far as I could tell.
Maybe I read the schematic wrong? The output is connected to the vertical line which connects the cathodes of the diodes? Pin 1 of the 4094 is connected to pin 15? Pin 10 and 11 of the 4093 are connected to pins 2 and 3, respectively?
jean bender
PostPosted: Wed Mar 07, 2012 10:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, i realized that all the outputs were the same...
I've tried several condensator values, little values are best... And i've sent the output bus to a lm386, in order to feed a little speaker...
It's my first design with a cd4094, i think it's a bit messy, but i'll go back to it as soon as i can, i think it can be improved.
I've never tried with pots, maybe it wouldn't work the same way... DOn't know.
But it's a really messy noise toy !
