Layouts for LogicOgic and LM239 Comparator Modules
Page 1 of 1 [3 Posts]
JRock
PostPosted: Wed Mar 07, 2012 9:55 pm    Post subject: Layouts for LogicOgic and LM239 Comparator Modules Reply with quote  Mark this post and the followings unread
Hi. I have some layouts for a Logic Based Module and a Comparator module.
The LogicOgic has a few AND/OR gates, a couple of FlipFlops and an Inverter/Buffer. There is a Daughterboard for a Quad SquareWave Oscillator bank.
LogicOgic
The Comparator Module is based on an LM239 Quad Comparator. You would probably be fine using a 339. I haven't tried though.
It has a variable threshold for each comparator. It has Gate and Trigger outs.
Both of them can be powered by 12V even though I have only used them with 15V.
Be careful! They deliver 11V-13V at the outs. If that freaks you out then tack on a voltage divider.
Good Luck thumb up
Sebo
PostPosted: Thu Mar 08, 2012 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
They look nice Smile
Thank you!
Sebo
My Music:
www.cosaquitosenglobo.com.ar
JRock
PostPosted: Thu Mar 08, 2012 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Sebo thumb up
Niio2
