Using foobar player for AmbiophonicDSP VST plugin
Page 1 of 1 [15 Posts]
Audio files: 143
PostPosted: Fri Jul 15, 2011 4:36 pm    Post subject:  Using foobar player for AmbiophonicDSP VST plugin Reply with quote  Mark this post and the followings unread
For several years I've been using Winamp with the VSTBridge plugin to play my stereophonic recordings using the AmbiophonicDSP plugin (see: http://electro-music.com/forum/topic-37687.html ), but lately problems have been showing up using the audio drivers on my XP and Vista computers. So, I've tried the Foobar2000 player. It's not a pretty, but it seems to be a much more solid player. If you are getting frustrated with Winamp, I suggest you give Foobar2000 a go. Here's how:
Download Foobar2000 and install from this link: http://www.foobar2000.org/
I downloaded the latest stable version.
Next download George Yohng's VST Wrapper for Foobar 2000 player. It is needed to enable foobar to load and use VST plugins, like the electro-music.com AmbiophonicDSP. See here: http://www.hydrogenaudio.org/forums/forums.html?showtopic=59206 for download link in instructions. Instructions are also included in the zip archive.
Next, just copy the AmbiophonicDSP.dll file, or other dll VST plugin, to the C:\Foobar2000\components directory (or where ever you installed it) on your drive. Activate the AmbiophonicDSP by clicking on the little blue VST image in the Windows toolbar, select the "Use VST Effect" menu item, select the AmbiophonicDSP VST plugin or whatever you are using, and enjoy your music.
It doesn't sound better than Winamp, but Foobar2000 is much more robust, at least for me. If Winamp is working for you, this won't be worth the trouble.
If you have questions or problems, post them here and I'll try to help you out. Thanks to electro-music.com user kraut for pointing me in the right direction on this.
ppw72
PostPosted: Fri Mar 09, 2012 8:55 pm    Post subject: Linux Ambio Setup
Subject description: Software
Hi Howard,
In case you or others are interested here's an outline of my setup running on Ubuntu using several open software packages.
Ladish - This is a jack session handler and works as the patch bay for all
the apps. Also handy for reassigning conflicting channel
assignment layouts. (Linux uses FL, FR, SL, SR, C, LFE instead of
the usual FL, FR, C, LFE, SL, SR.
Jack - Audio connection kit that allows you to connect jack compatible apps
together.
Jack Mixer - Controls the output levels and therefore the downmix of the
5.1/7.1 source to 4.0 for Ambio surround.
Festige - A wrapper that allows you to run Windows VST effects in Linux.
(Requires Wine - a Windows operating layer for Linux).
I'm using an audio player called Deadbeef for stereo music sources. It is simple but powerful and supports many features and formats. Very similar to Foobar actually. It only allows stereo output to Jack and doesn't support video, therefore I use VLC for video and multichannel sources.
The setup may sound a little convoluted but in practice it works really well. I have several Ladish session presets for various stereo and surround sample rates. I just open Ladish, load a session preset and it automatically opens all the apps and I'm ready to go. I've included a few screenshots of the system in action. (The screenshot doesn't capture the video but you get the idea).
I cannot tell you how much I'm enjoying the Ambiophonic plugin and its ability to elucidate the hidden gems within the soundscape. It's like the fresh eyes analogy applied to your ears! Thanks for sharing it with us.
All the best,
Paul
 Filesize:  209.67 KB
 Viewed:  423 Time(s)
 Filesize:  212.88 KB
 Viewed:  381 Time(s)
 Filesize:  190.25 KB
 Viewed:  359 Time(s)
janderclander14
PostPosted: Mon Mar 26, 2012 2:06 pm    Post subject: Re: Linux Ambio Setup
ppw72 wrote:
Hi Howard,
together.
All the best,
Paul
Hi!
From the screenshots I see you have set the delay value from the Ambio plugin to other than the default number.
Have you been able to store this value from one execution to another? I've tried several windows VST hosts and the delay parameter is always reseted to the initial value which is very annoying.
This does not happens with the other parameters whose values are correctly stored.
Regards
ppw72
PostPosted: Mon Mar 26, 2012 4:30 pm    Post subject: Re: Linux Ambio Setup
janderclander14 wrote:
Hi!
Regards
Unfortunately the delay setting is not stored between sessions and as you say this seems to occur across different hosts. Because my speakers are spaced at about twice the distance of the standard setup I simply double the delay setting each time. Another quirk I've noticed with the delay setting is that the default setting changes depending on the sample rate you are using. i.e. a higher sample rate will produce a lower default delay setting. It still functions correctly but the scale of the numbers is different. Sorry I couldn't be more helpful.
Kind regards,
Paul
janderclander14
PostPosted: Tue Mar 27, 2012 3:44 am    Post subject: Re: Linux Ambio Setup
ppw72 wrote:
Kind regards,
Paul
Indeed, the same happens to me. This seems to be easily fixable by developers. Could Mosc or RMiller provide a fix or a workaround for this?
Thanks
kraut
PostPosted: Tue Mar 27, 2012 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I run ambiophonics in foobar and have the presets stored in the presets pane.
Just select the settings, and add in presets with a name.
janderclander14
PostPosted: Wed Mar 28, 2012 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, but I'm affraid the delay setting is not stored within presets, at least in all VST I've tried.
Audio files: 143
PostPosted: Wed Mar 28, 2012 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a new version, AmbiophonicDSPv1.2 that will remember the delay setting in the presets. Please see this topic for more information.
http://electro-music.com/forum/topic-52843.html
janderclander14
PostPosted: Wed Mar 28, 2012 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much! It worked perfectly!
Audio files: 143
PostPosted: Thu Mar 29, 2012 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are there any other changes you would like? I may have missed some issues.
janderclander14
PostPosted: Tue Apr 03, 2012 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the delay value was the only issue, other than maybe the possibility of adding new features (e.g. multi-channel version, settings to adjust the frequency bandwidth to which apply the ambio effect, frequency oversampling to improve accuracy, etc.).
Are there any improvements planned?
Regards
Audio files: 143
PostPosted: Wed Apr 04, 2012 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not planned because you can use as many copies of the plugin as you need.
We have done a lot of experimentation and we find adding filters costs more in image clarity than it provides in benefits.
The plugin runs that the sample rate determined by the host program. If you can get your host program to oversample, the AmbiophonicDSP plugin will follow suit. Oversampling in the digital domain would only add problems since there are no non-linear operations. In this kind of DSP, a the most dangerous thing is not having enough headroom (dynamic range). Internally, we deal with that problem, but using 24 bit audio is one thing you can do as a user, but it won't make much of an audible improvement.
kraut
PostPosted: Sat Apr 07, 2012 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I installed the new version, works well.
But why is this file smaller than the original one?
Nothing seems to be missing. Streamlined?
Audio files: 143
PostPosted: Sat Apr 07, 2012 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't notice that. All I can suggest this that it was compiled by a newer version of the compiler. Is this proof of evolution?
kraut
PostPosted: Sat Apr 07, 2012 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess in your case not even intelligently designed, so yes, Darwinian.
