  Antimon Antimon Waves
Sort of Buchla/Serge-ish panels designed for DIY projects
Page 1 of 1 [2 Posts]
ericcoleridge
PostPosted: Tue Mar 13, 2012 12:30 pm    Post subject: Sort of Buchla/Serge-ish panels designed for DIY projects
Subject description: 5 Panels that make up a Serge boat
These are panels that I made several years ago before I started making actual reproductions. I did wire a couple, but I've since re-purposed the PCBs I was using and have no plans to use these panels anymore.
They are Buchla/Serge height, and all together span 17", for a typical Serge boat. I was going to use 1/8" jacks, but I'm sure they could be bore out for Bananas.
If anyone wants them, you're welcome to them, and I can give more info on what circuits they were intended for. I'm sure they were at least $30 each from Front Panel Express, so I'd like maybe $25 for each. They're actually very nice, they have a kind of sparkle to the finish. The graphics are laser etched and filled in with blue ink.
1. The one with sliders, top left, was for two Korg Resonators (PCBs on Foniks site). I have the sliders.
2. Moving right, the next is for 6 (!) Buchlaesque CV Processors, and two summing busses at the bottom (CV Proc on Fonik's).
3. Next is a Quad Fun Gen, as offered by Topp;
4. Next is a Quad LPG (PCBs on Fonik's)
5. The last on on the right is for MFOS Noise Cornecopia, MFOS Sample and Hold, and CGS Analog Shift Register.
I have the black skirted knobs and could include them too. I think these would look very nice with Serge knobs also, or maybe a combination. The functionality here is quite dense and would fit in well, in many ways, with a DIY Serge system.
ericcoleridge
PostPosted: Thu Mar 15, 2012 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also have DIY Quad Low Pass Gate PCBs for the panel above. It's two stacked dual LPGs, hand etched, fully assembled, and tested as working-- but from several years ago.
The stacked PCBs are only about the size of one of one Thomas White LPG and will fit behind the panel above.
Someone recently did a run of those Buchlidian Voltage Processors on the Muff forum, I don't know what they look like, but they're probably small to stack behind the above panel.
