Ambiophonic plugin for foobar
j_b
PostPosted: Fri Mar 23, 2012 8:46 am    Post subject: Ambiophonic plugin for foobar Reply with quote  Mark this post and the followings unread
This is a native foobar plugin; no VST wrapper required. It works with any file format and sample rate that foobar supports. The plugin calculates the delay from the speaker geometry but the calculated value can be over-ridden with whatever you choose. It has an A/B switch to allow comparisons between different parameter settings. The operational settings can be overridden by music file tags or a preset in the directory that contains the music file. Built-in four channel support plus other features I found useful for testing.
foo_dsp_ambio.zip
 Filename:  foo_dsp_ambio.zip
 Filesize:  343.41 KB
 Downloaded:  189 Time(s)
emSynth
