<on air> Muied Lumens Frequencies
2012 Build Pictures
Page 3 of 16 [384 Posts]
Goto page: Previous 1, 2, 3, 4, 5, ..., 14, 15, 16 Next
sduck
PostPosted: Fri Feb 17, 2012 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I understand that every decent modular needs at least one decent quantizer. Now I have 8 -
Craig Lee 8 Channel Quantizer front
Craig Lee 8 Channel Quantizer profile
Craig Lee 8 Channel Quantizer back
Rvlt
PostPosted: Wed Feb 22, 2012 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice!
Did you buy this PCB somewhere or is this your factory-made prototype? I found Craig Lee's website with all the schematics, but no hint of a pcb.
Just curious..
Lars
Mongo1
PostPosted: Wed Feb 22, 2012 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Craig used to sell the PCB - some of us are trying to convince him to do that again...
Gary
frequencycentral
PostPosted: Wed Feb 22, 2012 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Electric Druid VCADSR, emulation of CEM 3312 and SSM 2056, based on PIC16F684. This is the simple version, with global time CV and attenuator, doing the full-on version with seperate CV over A, D, S and R next. The sockets of the left that look like multiples are.....multiples.
http://www.frequencycentral.co.uk/
Sonic
PostPosted: Sat Feb 25, 2012 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I went to the Metal Supermarket this week and had them make me up some aluminium panels. Here is my first panel. The module is a Quad 40106 VCO. I'll wire it up tonight.
 Filesize:  802.03 KB
 Viewed:  205 Time(s)
 Filesize:  769.31 KB
 Viewed:  227 Time(s)
Mongo1
PostPosted: Sat Feb 25, 2012 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks nice! Can you provide more details on the metal you ordered? Gauge and type??
Thanks
Gary
Sonic
PostPosted: Sat Feb 25, 2012 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
The gauge is 0.08" which is plenty stiff enough for my 8.75" tall panels. I find 0.063" is too flexible (unless you put a bend in it - not easy by hand). 0.125 is too thick: once combined with the piece of L-bracket I use to mount the circuit boards it would be too thick for the thread on the pots to still protrude enough to secure them with the nuts.
I can't remember what the type is. I had intended to buy 6061 but they didn't have it in the right gauge, so I just went for something else they had on the floor.
Mongo1
PostPosted: Sat Feb 25, 2012 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info - I recently did a module with a bridechamber blank front panel, and had the issue you mentioned with the pot threads. I think if I go with more bridechamber panels I'll have to use his brackets as well. I stopped doing that because I use the 1" grid for my controls, so the pot holes on the bracket are a problem.
Oh well nothing's easy....
Gary
kaputtpanzer
PostPosted: Wed Feb 29, 2012 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a Video for my media art school application. For the sound I used a Sawtooth generator, MS20 VCF and some Lunetta...
WATCH IN HD Twisted Evil
janvanvolt
PostPosted: Sat Mar 03, 2012 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice, very "avantgarde" in both musical and video Smile
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
strategy
PostPosted: Sun Mar 18, 2012 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
the mighty DS8!
community-library.net/strategyhome.htm
frequencycentral
PostPosted: Wed Mar 21, 2012 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
A couple of new ones from me
"Recycler" based on the forthcoming Electric Druid LoopEnv1 PIC. This is the full-on version featuring:
- voltage control over A, D, S, R and global time
- 'Out' 0v - 5v out for envelope use
- 'BP' (bipolar out) +/-5v out for VCLFO use
- three way mode switch ADSR/Gated looping/Looping
- Lin/Log switch - Lin is good for VCLFO modes, Log for VCASDR mode
From this thread: http://www.muffwiggler.com/forum/topic-51707.html
Next up, "Multimode" super simple LM13700 multimode VCF prototype:
Finally, "Utility", Roland System 100M 132 CV Mixer/Voltage Processor, with multiples.
From this thread: http://www.muffwiggler.com/forum/topic-55407.html&highlight=
jordroid
PostPosted: Sun Mar 25, 2012 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Not exactly a synth, but it does make synths louder, a tube amplifier i just finished using an old RCA carcass that a friend of mine gave me. Two 6SL7s and a 6SN7 for the preamp, two fixed bias 6L6GCs for the poweramp and a tube rectifier. It's the first one i have done all point to point, and i ended up really liking that construction style, it looks kind of crazy inside but everything is right where i want it, and it sounds great with very very low noise.
jordan
 Filesize:  120.19 KB
 Viewed:  188 Time(s)
 Filesize:  98.08 KB
 Viewed:  199 Time(s)
Audio files: 140
PostPosted: Tue Mar 27, 2012 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Yay! Tubes! Very Happy Ohm...
frequencycentral
PostPosted: Tue Mar 27, 2012 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Roland 100M 121 VCF clone using 4 x CA3080. I've added a very nice extra feature:
- additional 12dB/oct audio output
.......which is...
- inverted with respect to the stock 24dB/oct output
.......therefore...
- mixing the two outputs together results in phase cancellation and therefore bandpass mode
.......and also really interesting to use the two outputs for stereo.
Full project files and PCB availability within a few days.
Audio files: 550
PostPosted: Wed Mar 28, 2012 12:49 pm    Post subject: DIY Synth stuff by PHOBoS Reply with quote  Mark this post and the followings unread
2 of the cases with some of the circuits which were originally ment to be part of the dronoscope.
Case1: AHD LFO/DUAL VCA/DUAL WAVEFOLDER/VCO/VCF
Case2: Mad Monkey Sequencer/Divider
more info in this thread.
edit: just noticed I don't have the yellow cover on the reset switch of the divider.
(just imagine it's there for now Wink)
SynthBox 1 - AHD LFO, DUAL VCA, DUAL WAVEFOLDER, VCO, VCF
 Filesize:  708.04 KB
 Viewed:  196 Time(s)
SynthBox 2 - Mad Monkey Sequencer and Divider
 Filesize:  719.84 KB
 Viewed:  213 Time(s)
Audio files: 550
PostPosted: Wed Mar 28, 2012 1:32 pm    Post subject: EMF Detector and White noise generator Reply with quote  Mark this post and the followings unread
And here's something I just finished. Not really a synth but it does make sound.
It's an EMF Detector and White noise generator alien
I noticed that when you bring the pick-up coil close to the meter it starts to oscillate.
So I attached a little coil to the switch contact of the jack for the pick-up coil
and glued it onto the back of the meter. So I can make nice tweeps with it.
The tip of the meter has some neonpaint on it so I added 2 UV LED's to the sides of it.
EMF Detector and White Noise Generator by PHOBoS
 Filesize:  83.1 KB
 Viewed:  214 Time(s)
EMF Detector and White Noise Generator in darkness (sorry for the blurry pic)
 Filesize:  19.44 KB
 Viewed:  178 Time(s)
PostPosted: Wed Mar 28, 2012 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great looking cases Phobos!
JacobWatters.com
tjookum
Audio files: 26
PostPosted: Thu Mar 29, 2012 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing work Phobos(as always)!
Did you make the panels yourself? They look absolutely stunning.
Hunter S. Thompson
movies
noise
Audio files: 550
PostPosted: Sat Mar 31, 2012 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Cyno, Tjookum Very Happy
yep, designed in photoshop and printed on paper. more info in the last part of this post.
JingleJoe
PostPosted: Sat Mar 31, 2012 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Phobos, that EMF detector looks marvelous! I made one once which looked slightly similar (lots of knobs and a meter) but that was before I really knew anything about electronics. Sold it to an american ghost hunter Laughing
Any chance of getting some sound examples of your device?
Also, rather than a photo of something I've built, here is a photo of the building process in my lab Smile
 Filesize:  3.06 MB
 Viewed:  742 Time(s)
Audio files: 550
PostPosted: Sat Mar 31, 2012 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks, funny you mention ghost hunter, I made it for possible EVP recordings, that's why I also added the white noise generator Wink
and as for sounds, I just did a session with the EMF detector, dronoscope, and 2 synthboxes a few days ago
which will be uploaded shortly (Hope to get that done this weekend)
but right now I'm working on a circuit called the jingler named after some mad scientist here on the forums Cool
nice meter btw!
JingleJoe
PostPosted: Sat Mar 31, 2012 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
nice meter btw!
Let me take this oportunity to say, if you like that one take a gander at these Wink
(Thats not even anywhere near half of all of them Laughing)
vladosh
PostPosted: Mon Apr 02, 2012 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is the synth so far ,very much ghetto style but all is working fine ,missing a sequence in the picture and so i guess also missing a lot of fun so that's next or so ,and just to say thanks to all the folks in the chatroom that been really helpful ,all the circuits are not over complicated ones and all is build on stripboard except for a mfos vco , the modules are : VCA X 2, Wave Wiper, CGS Slope Detector, Magic Smoke LFX, Oberheim EFM clone - VCF, Seq Switch X 2, Analog Neuron, Jerk Off - Chaos module, CV Twister, Music From Outer Space - VCO, Morphlag ,Grinder and Voltage Mixer
 Filesize:  73.86 KB
 Viewed:  728 Time(s)
JingleJoe
PostPosted: Mon Apr 02, 2012 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
vladosh wrote:
This is the synth so far, very much ghetto style
Thats the best style of all, because it means you are probably putting function over form Wink
