Wavefolder DC Output
Page 1 of 1 [5 Posts]
freiburg
PostPosted: Sat Mar 24, 2012 5:49 am    Post subject: Wavefolder DC Output
Subject description: My Wavefolder produces DC Output, is this ok????
Hello everybody
I am not sure whether my wavefolder operates properly:
Range Pot on minimum (ground), sine wave at input. Control Voltage on ground. The output produces a DC ranging from -2V up to +0.5V depending on the position of the shape pot.
Beside of that the module does wavefolding, although in my opinion the sweet spot of the shape pot is somewhat small.
so i am not sure whether this device operates properly or not. any advices and comments are welcome.
christian
Sebo
PostPosted: Sat Mar 24, 2012 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Seem like your CV is leaking into the VCA.
Do you calibrated the VCA?
Sebo
My Music:
www.cosaquitosenglobo.com.ar
freiburg
PostPosted: Sun Mar 25, 2012 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
yes calibration of the vca worked without problems and is very accurate.
so you say, some dc output is in fact a malfunction?
yusynth
PostPosted: Mon Mar 26, 2012 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you match the trannies of the VCA ?
Yves
freiburg
PostPosted: Mon Mar 26, 2012 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes within 2mV
