varice
Joined: Dec 29, 2004 Posts: 626 Location: Northeastern shore of Toledo Bend
G2 patch files: 46
Posted: Thu Sep 22, 2011 1:04 am Post subject:
| dorremifasol wrote: | | Lately I've been thinking of buying a Moog Slim Phatty. It should work very well with the G2, and I suppose it can also be used only as a filter like in your mod. |
| varice wrote: | | Yes, the Phatty has external inputs for audio and CV, so it could be used this way. You would have the option of mixing the Phatty’s sound sources with the G2’s before the filter, and the option to use the G2 for CV control (with a G2 DC output modification, of course) or just use the Phatty’s EG and modulation for the filter. Then the audio output of the Phatty could be connected to a G2 input for more processing/FX treatment. It should work like a charm!... |
| dorremifasol wrote: | | Finally I got a Slim Phatty (my first Moog!) and I must say that I'm really satisfied with the G2 - SP combo and the way how they can interact with each other. Wonderful sound and possibilities!... |
Hey Albert – Congratulations for scoring a Moog Slim Phatty to use with your G2! Have you tried patching G2 sound sources to the Phatty audio inputs and the Phatty output back into a G2 input for processing/FX treatment?
Attached to this post is one of my recent patch templates that I have been using with my G2X/moogerfooger filter monster that you may like to try with your G2 and SP. So basically, the raw G2 sound output is patched to the G2 audio output 3 which you would connect to the SP audio input. Then connect the SP audio output to the G2 audio input 3 (the G2 audio outputs 1 and 2 are used for the main stereo output). In this case, you have the option of using the SP or the G2 for the final VCA. The quickest results may be to use my G2 amplitude EG settings and set the SP volume EG to the fastest attack, the max sustain level, and the longest release parameter settings. This patch is based on modifications of the “mono monster VM” patch that I posted earlier along with some detailed patch information over here:
http://electro-music.com/forum/topic-9258.html
But, this patch posted here in this topic has a moogerfooger filter cutoff DC CV output patched to the G2 audio output 4 to be used with my modified G2X, so be sure to disconnect or fade out this audio output connected to any audio mixers. Since you have not modified your G2 for DC CV output, you would need to use the SP filter cutoff EG and modulation instead with this patch. I suggest that you look at the G2 patch parameter settings for filter cutoff, EG, and modulation as a guide to set the SP filter and modulation parameters and that you set the SP filter resonance to about 60%. And be sure to check out all of the patch variations…
 Download |
| Filename: |
mm 3 Osc mf.pch2 |
8.03 KB |
| Downloaded: |
230 Time(s) |
_________________ varice |
dorremifasol
Joined: Sep 28, 2006 Posts: 757 Location: Barcelona, Spain
Audio files: 6
G2 patch files: 47
Posted: Thu Sep 22, 2011 2:00 am Post subject:
Thank you Varice! I'll try the patch tonight, at home.
Yes I connected the G2 and the Phatty one with each other, so I can send audio to the Phatty (out 3) and get it back to the G2 again (in 3). The Phatty has 2 audio outputs (main and headphones), so I can have one output always connected to the G2, and the other to the soundcard.
The Phatty also has a MIDI merge function, so I can connect the G2 directly to it, and then to the computer without using an additional MIDI interface (thumbs up for this feature!!). It also has an USB MIDI port, but this way I can use both synths without having to turn on the computer.
But to me the most exciting thing is that since all the parameters in the Phatty can be edited via CC#, I can expand its capabilities using modules inside the G2 (envelopes, LFOs, sequencers, etc). Moreover, since the Phatty already has an LFO and 2 envelopes, I can use them when I need really fast modulations. The filter envelope can be used to modulate other things as well.
There are many important parameters in the Phatty that can't be edited from the front panel (ie. number of poles in the filter, additional modulations...), but again, since all is also changed via CC# I can create a patch in the G2 to control these parameters with the excellent G2 interface. I hope to experiment a lot this weekend ^_^
I feel very lucky. I got the Phatty from a guy who bought it, and sold it to me just the next day for 160€ less. I couldn't be happier.  _________________ Cheers,
Albert |
varice
G2 patch files: 46
Joined: Apr 03, 2004 Posts: 19593 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat Mar 24, 2012 8:17 pm Post subject:
| varice wrote: | Some on the internets say that you have to post a picture of your exploits to prove that it really happened  |
good reading
nice floor too! and a bit of a mystery pic  _________________ Jan |
varice
G2 patch files: 46
Posted: Sat Mar 24, 2012 9:25 pm Post subject:
| Blue Hell wrote: | | ...nice floor too! |
Thanks Jan Yes, I think the floor is nice. And the other parts of the room aren’t too bad either
| Blue Hell wrote: | ...and a bit of a mystery pic  |
I’m curious – what do you find mysterious about this picture? _________________ varice |
Audio files: 116
G2 patch files: 317
Posted: Sun Mar 25, 2012 5:50 am Post subject:
The mystery is what is not on the picture - on the right side I mean, so how it was cut off (for it's purpose of course). _________________ Jan |
varice
G2 patch files: 46
Posted: Sun Mar 25, 2012 2:08 pm Post subject:
Oh, right, the other bits in the picture!
Just above the G2X is a Roland MC-909 Sampling Groovebox loaded with the max sampling RAM and a SRX-01 Dynamic Drum Kits ROM waveform expansion.
http://en.wikipedia.org/wiki/Roland_MC-909
At the top of the picture is the bottom of the left loudspeaker pair, JBL 250Ti, that I use for listening to stereo music and as studio monitors. Mine are finished in Burmese teak.
http://www.audioheritage.org/html/profiles/jbl/l250.htm _________________ varice |
varice
G2 patch files: 46
iPassenger
Joined: Jan 27, 2007 Posts: 1051 Location: Sheffield, UK
G2 patch files: 78
Audio files: 116
G2 patch files: 317
Posted: Tue Mar 27, 2012 5:44 am Post subject:
Nice! _________________ Jan |
dorremifasol
Audio files: 6
G2 patch files: 47
Posted: Tue Mar 27, 2012 5:45 am Post subject:
Spacious! _________________ Cheers,
Albert |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Tue Mar 27, 2012 2:22 pm Post subject:
| varice wrote: | At the top of the picture is the bottom of the left loudspeaker pair, JBL 250Ti, that I use for listening to stereo music and as studio monitors. Mine are finished in Burmese teak.
Yikes, those speakers are purr-fect for Ambiophonic Stereo and you have the setup space to move them closer together. Get the AmbiophonicDSP and if you don't think it's the greatest thing in audio, I'll refund your $10.00. (Offer applies to everyone else too, for that matter).
http://electro-music.com/catalog/product_info.php/products_id/114 _________________ --Howard
my music and other stuff |
dorremifasol
Audio files: 6
G2 patch files: 47
Posted: Tue Mar 27, 2012 3:03 pm Post subject:
Excuse the off topic, but does the plugin work with headphones? _________________ Cheers,
Albert |
Audio files: 107
Posted: Wed Mar 28, 2012 11:06 am Post subject:
The AmbiophonicDSP is meant for use with two speakers spaced close together in front of the listener. It's not a good idea to use headphones with it, but we are working on something for headphones to be released later. _________________ --Howard
dorremifasol
Audio files: 6
G2 patch files: 47
Posted: Wed Mar 28, 2012 11:37 am Post subject:
Thanks for the info. Unfortunately I use headphones almost exclusively since I'm only at home at night, and also I live in a small flat.  _________________ Cheers,
Albert |
varice
G2 patch files: 46
Posted: Wed Mar 28, 2012 5:57 pm Post subject:
| mosc wrote: | | varice wrote: | At the top of the picture is the bottom of the left loudspeaker pair, JBL 250Ti, that I use for listening to stereo music and as studio monitors. Mine are finished in Burmese teak.
http://electro-music.com/catalog/product_info.php/products_id/114 |
I tried your G2 version of the Ambiophonic encoder not long after you posted it, but with a smaller set of speakers (as each 250Ti speaker weighs more than 100 lbs which doesn’t allow for easy movement for sonic experiments). The encoded sound was “phasey” (comb filtered) and the frequency spectrum was colored too much. I tried tweaking the G2 parameters and different speaker separation angles, but I never could get a result that sounded better to me than normal stereo. Maybe after listening to HiFi stereo for the last 40 years and these excellent 250Ti speakers for the last 26, I have grown accustomed to the interaural crosstalk and don’t perceive it as a significant problem.
Does the VST work significantly better than your G2 version? _________________ varice |
varice
G2 patch files: 46
Posted: Wed Mar 28, 2012 7:07 pm Post subject:
| dorremifasol wrote: | | Spacious! |
Hey Albert,
Yes, it is nice to have more studio space, although my room is not huge, only about 15 x 23ft, or 5 x 7.67m. But, this is still larger than the small studio rooms in all the apartments where I lived before I retired. And my 250Ti speakers sound much better in a larger space, where I can also crank up the volume without worrying about disturbing my neighbors . _________________ varice |
varice
G2 patch files: 46
Posted: Wed Mar 28, 2012 8:09 pm Post subject:
| dorremifasol wrote: | | Excuse the off topic, but does the plugin work with headphones? |
| mosc wrote: | | The AmbiophonicDSP is meant for use with two speakers spaced close together in front of the listener. It's not a good idea to use headphones with it, but we are working on something for headphones to be released later. |
| dorremifasol wrote: | …Unfortunately I use headphones almost exclusively since I'm only at home at night, and also I live in a small flat.  |
Albert, I hear you brother…
Stereo headphone listening has a problem that is the opposite of normal stereo speaker listening: a total lack of natural interaural(sp?) crosstalk by sounds that are panned hard left or right. While the Ambiophonic encoder attempts to eliminate crosstalk for stereo speaker playback, stereo headphone playback could be enhanced by adding a more natural crosstalk. Years ago in my apartment dwelling days, I patched a headphone enhancement for my G1 micro modular that I think sounded very good. But, trying to patch this in the G2 didn’t seem to work as well. But anyway, I could dust off and polish up my G2 headphone patch for those that are interested… _________________ varice |
Audio files: 116
G2 patch files: 317
Posted: Thu Mar 29, 2012 5:19 am Post subject:
| varice wrote: | | I could dust off and polish up my G2 headphone patch for those that are interested… |
I'd be intersted to see it - like Albert I use headphones mostly as well.
Edit: and the NM Classic version as well ;-) _________________ Jan |
Audio files: 107
Posted: Thu Mar 29, 2012 1:46 pm Post subject:
| varice wrote: |
Does the VST work significantly better than your G2 version? |
Yes. The G2 was a first try and the algorithm is very old relative to the plugin. There are other issues with the G2 and feedback which are well know. For me, the experiment was enough to drive my interest to continue research.
There is the free plugin you can try which is better than the G2, a bit. The new plug in is much improved over that though. The new one has the ability to adjust the active parameters. You can control the "phaseness" as you prefer. The "space" control does this. _________________ --Howard
dorremifasol
Audio files: 6
G2 patch files: 47
Posted: Thu Mar 29, 2012 9:35 pm Post subject:
| varice wrote: | | Stereo headphone listening has a problem that is the opposite of normal stereo speaker listening: a total lack of natural interaural(sp?) crosstalk by sounds that are panned hard left or right. |
This is slightly more bearable with open cans, like the AKG K701 I use, absolutely necessary to hear the wife complains. I'm in serious love with these headphones, except that the headband is all the contrary of comfortable. Fortunately it can be somewhat fixed with some foam.
I see wood inside and trees outside, how I envy you! _________________ Cheers,
Albert |
3phase
G2 patch files: 138
Posted: Thu Apr 05, 2012 3:51 pm Post subject:
sounds interesting..to bad that its only windows.. i wonder if it would be suitable for a live pa... |
varice
G2 patch files: 46
Posted: Mon Apr 09, 2012 9:33 pm Post subject:
| 3phase wrote: | | mosc wrote: | | varice wrote: | At the top of the picture is the bottom of the left loudspeaker pair, JBL 250Ti, that I use for listening to stereo music and as studio monitors. Mine are finished in Burmese teak.
Probably not. It appears that it is meant to be used by one listener lined up along the center line of two closely spaced stereo speakers. A condition that would not normally occur in a live PA venue. _________________ varice |
varice
G2 patch files: 46
Posted: Mon Apr 09, 2012 9:39 pm Post subject:
| Blue Hell wrote: | | varice wrote: | | I could dust off and polish up my G2 headphone patch for those that are interested… |
Edit: and the NM Classic version as well  |
A new G2 version of my headphones processor patch is posted here:
http://electro-music.com/forum/post-358486.html#358486
The most up to date G1 version is on my Micro Modular which is still in storage, so I don’t have immediate access to it, but this G2 version is tweaked to sound better than my previous G2 patch work.  _________________ varice |
3phase
G2 patch files: 138
Posted: Wed Apr 11, 2012 11:26 pm Post subject:
| varice wrote: | | A condition that would not normally occur in a live PA venue. |
that depends on how you place the speakers... |
