  Muied Lumens Frequencies
Another Additive FPGA Synth
Page 1 of 1 [10 Posts]
JovianPyx
Audio files: 190
PostPosted: Wed Mar 28, 2012 5:32 am    Post subject: Another Additive FPGA Synth Reply with quote  Mark this post and the followings unread
I've modified an earlier additive (sine) synthesizer to do something a bit different.
My previous additive synth (32 sine oscillators) was designed to produce periodic waveforms and used the sine oscillators as harmonics, i.e., each oscillator has a frequency that is an integer multiple of the fundamental pitch.
Blue Hell suggested the use on inharmonic partials (not harmonics). These are calculated using multiplication factors other than integers to produce partials of higher frequency than the fundamental pitch. He also suggested that a scale might be constructed out of the partial frequencies (or lower octaves of them).
The result was interesting gong and bell like sounds, metallic sounds. I had been reading that gongs and bells can have inharmonic partial stucture and that because of this structure it can be difficult to hum the pitch of the gong because of the strong influence of partials above the fundamental. This seems true of the output of my synthesizer as well.
I will be working on some kind of a demo which I will post later today.
Time flies like a banana.
corruptio optimi pessima
Audio files: 218
G2 patch files: 319
PostPosted: Wed Mar 28, 2012 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, lift off Cool
JovianPyx
Audio files: 190
PostPosted: Wed Mar 28, 2012 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the first demo sample. I'll do more because settings affect the sound. This was just one setting. I played random notes (this is a monosynth) and let the DDR SDRAM echo/delay effect fill in.
InharmonicSynth_01.mp3
Inharmonic Additive Synth Demo 01
 Filename:  InharmonicSynth_01.mp3
 Filesize:  2.38 MB
 Downloaded:  468 Time(s)
JovianPyx
Audio files: 190
PostPosted: Wed Mar 28, 2012 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I will be adding more samples here in this reply as I create them.
InharmonicSynth_02.mp3
More Inharmonic Synth Bells
 Filename:  InharmonicSynth_02.mp3
 Filesize:  3.08 MB
 Downloaded:  456 Time(s)
InharmonicSynth_03.mp3
And another one
 Filename:  InharmonicSynth_03.mp3
 Filesize:  3.01 MB
 Downloaded:  432 Time(s)
InharmonicSynth_04.mp3
Too Many Clocks All Set to the Wrong Times
 Filename:  InharmonicSynth_04.mp3
 Filesize:  3.08 MB
 Downloaded:  419 Time(s)
Audio files: 218
G2 patch files: 319
PostPosted: Wed Mar 28, 2012 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice bells Scott!
JovianPyx
Audio files: 190
PostPosted: Wed Mar 28, 2012 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a composition I call "Inharmonic Rag"
The scale used was created from the partials' frequencies.
Inharmonic_Rag.mp3
Inharmonic Rag
 Filename:  Inharmonic_Rag.mp3
 Filesize:  2.96 MB
 Downloaded:  449 Time(s)
JovianPyx
Audio files: 190
PostPosted: Mon Apr 02, 2012 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
This synthesizer was small enough that I was able to double up on the hardware and modify the MIDI controller to make a duophonic synthesizer. Basically, 2 monosynths each with 32 sine oscillators. The sample rate is still 250 kHz.
It sounds much better than the monophonic version because you can play 2 notes at once or in rapid succession and don't get a weird pitch burp sound.
The demo is bits of playing, pause, bits of playing, pause, etc. The pauses were actually a bit longer as I was changing the patch. Each of the segments have some settings different. There is also a 1 second echo effect.
Duophonic_Inharmonic_Additive_Synth_Demo.mp3
Duophonic Inharmonic Additive Synth Demo
 Filename:  Duophonic_Inharmonic_Additive_Synth_Demo.mp3
 Filesize:  3.73 MB
PostPosted: Mon Apr 02, 2012 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
It sounds awesome!
What kind of filtering do you do the the sine wave to give it the bell type of sound? Is it just the cross modulation from 32 oscillators?
JacobWatters.com
JovianPyx
Audio files: 190
PostPosted: Mon Apr 02, 2012 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cynosure wrote:
It sounds awesome!
This synthesizer has no filter.
It's much simpler, all I do is add the outputs together - imagine a 32 channel mixer, each with a sine wave that let's you control the frequency. It's digital in this case, but it works the same way. I can set the levels and frequencies of these 32 sine oscillators.
The reason it's like a bell is because the sine wave frequencies intentionally do not have an integer relationship to one another. This produces a non-periodic waveform, i.e., it doesn't have a waveshape like tri or saw. Metal bells often if not usually have partials instead of harmonics. The partials are sinewaves that don't relate to a fundamental in a simple integer way. A sawtooth, for example, has harmonics that are 2x 3x 4x 5x...etc. of the fundamental frequency. My synth is designed to make other relationships instead of integer.
Hopefully, that answers the question...
PostPosted: Mon Apr 02, 2012 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. Thanks!
JacobWatters.com
