Transformer Help
Page 1 of 1 [13 Posts]
crazeydazey
PostPosted: Wed Apr 04, 2012 2:09 am    Post subject: Transformer Help Reply with quote  Mark this post and the followings unread
Hi all..
not been around for a while had lots to do, new job, babies etc..
But now I'm back and hopefully gonna get some of my projects finished.
First thing I thought I'd best finish my PSU... so I have bought a 240v 2A secondary 48VA 0-12-0-12 VAC transformer... great I should be able to get some power now and start making some noise Smile
It's come today and the sticker on it has baffled me somewhat, so before I blow myself up I just want to check with you guys (if thats ok)
it has a brown and blue wire, which I think is fair to say is the primary and on the sticker it says brn 0V - blu 240V (I know it doesn't really matter, but isn't that the other way round???)
then the other side has Red, Yellow, Black and Grey wires and the sticker says - Red 0V - Yel 12v - Blk 0V - Gry 12V, so I guess that means this...
Code:
Blue 0v Neutral   ____   ____  Red 0V
                     )||(____ Yellow 12V
                     )|| ____| Black 0V (black and yellow connected together)
Brown 240V Live  ____)||(____ Grey 12V
So now I have 3 wires going to my Power supply board (which will become +12v - GND - -12V)
I'm sure this is right, it seems really obvious and I'm quite embarrassed asking.. but I don't really want to blow my silly self up Smile
cheers all[/code]
My Site
mrkva
PostPosted: Wed Apr 04, 2012 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
So first of all - watch out when dealing with AC mains, its not fun to touch the wrong wires!
Suggested setup should be giving you +/-/12 and ground, BUT for PSU giving you 12V you probably need to provide higher voltage! I've succesfuly built one with transformer giving 15V.
You can definitely test it out with this setup and see for yourself if the regulators give you proper voltages.
Audio files: 51
PostPosted: Wed Apr 04, 2012 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I would agree,
A 12-0-12 transformer will really equate to +/-9VDC once you get past the rectifier and any kind of regulation. Crying or Very sad
For a solid +/-15V system, you really need an 18-0-18 transformer, at least. Cool
Don't be discouraged by buying the one you did though. Idea
A good +/-9V supply on your bench will prove it's worth over and over and over. Wink
BTW,.... "shouldn't that be the other way around?"
Well, yes,... in a way.
The Neutral should be across a fuse to ground at you main power box. The Active,... is just that... active (that is 240VAC (around here)), but if the electrician swapped the leads at the input, it wouldn't make any difference. Remember, we're in the land of Potential.
And,............... Keep in mind that,..... inspite of the fact that vitually everyone speaks of the +ve as the "resource", all current flow is actually from the -ve to the positive (as far as electron flow goes)
Welcome back to a very rewarding hobby! too much coffee
We would lose our friends.
So,.........
crazeydazey
PostPosted: Wed Apr 04, 2012 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
ah bugger... I am a little bit gutted, but like you say it will still come in handy, maybe for my soundlab as thats +-9V.
the reason I'm gutted is the board I have is for +-15v and I was told I could use a 24VCT transformer.. have I misunderstood.. I thought 24VCT meant 12-0-12-0 and the centres joint together??
is my diagram correct though.. do I join yellow and black, I wouldn't like to join the wrong two (say red and yellow.. I guess thats not a very healthy idea???)
Is there any way I can test with a meter before wiring up.. say a resistance test on red and yellow and black and grey and then red and grey and black and yellow (I assume as they are too separate windings I shouldn't get anything from say red and black or red and grey for example??)
cheers uncle K Smile
My Site
jordroid
PostPosted: Wed Apr 04, 2012 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
The easiest way to determine the phasing of a transformer is with a dual channel scope, but there is a trick at the bottom of the (very informative) article here http://www.freewebs.com/valvewizard2/Transformers.html
Sounds like you are on the right track.
regards,
jordan
Audio files: 69
PostPosted: Wed Apr 04, 2012 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi There
just to re-cap , can i ask what the total load per regulator will be , type of regulator 78 / 79 or adjustable ones , and whether your using 1 bridge rectifier or 2 bridge design , thanks .
Regulators usually need a sweet spot 3volt drop over them (example - 15 in 12 out) but when i was first designing my supply , in error i thought i could load up the whole modular on a pair of regulators , i did create some fantastic heat from the 5 inch X 5 inch heatsinks (there is still a bare patch where hair used to grow on my arm Smile ) .
My original transformer was a 18/0 18/0 , after the rectifying stage the voltage was 20v , 20v in 12v out was a 8v drop over the 12v regs and that dissapated as heat , searing heat with 40 odd modules running , then they shut down in disgust Smile.
Your transformer may or may not satisfy the regulators by the time it goes through the bridge but a 15/0 15/0 will be better in the long run.
hope i didnt mumble too much there Very Happy
good luck & fire any questions to us here.
www.myspace.com/skrogproductions
Audio files: 69
PostPosted: Wed Apr 04, 2012 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
here's the thread for the blue wardrobe supply http://electro-music.com/forum/topic-48193.html&highlight=
Osal
PostPosted: Thu Apr 05, 2012 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes your diagram seems correct.
For a typical bipolar power supply, ike my PS1, the secondaries must be in series and out of phase.
To know if they are in series , resistance is twice the resistance of one secondary.
To know if they are out of phase Jordroid already have said it.
By the way you can output +-15V from a 15-0-15 transformer, using my PS2 an therefore reducing very very much the size of the heat-sinks.
http://electronic-sea.net/ps2.html
electronic-sea.net
crazeydazey
PostPosted: Thu Apr 05, 2012 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi skrog..
I don't think I can answer most of your questions I'm afraid, I bought the board ready built, just needed to add the transformer and was told the one I got should do..
I can see that the regs are 7815 and 7915 and I can see a bridge rectifier on the AC in and a couple of 1n4002 on the DC out (guess that doesn't make it a 2 bridge design though eh Smile - sorry, I'm still pretty new to synth DIY)
seen your PSU, it looks pretty dam cool and all your modular in the back (I'm jealous - I've just about finished WSG, Soundlab and a PSU, I guess we all have to start somewhere)
I have done a bit of poking around with the meter and everything looked ok (thanks jordroid for the link that was quite useful), so went ahead and connected it up and plugged it in and it didn't go bang, so that was nice Smile, took some readings.
I get +15.1v and -14.8v. is this ok, do they both need to be the same?? do they both need to be bang on 15v??
now I do get 15v is it still not really gonna be good enough, am I better getting say a 18-0-18-8 (allowing then for the 3v drop) and using this one for my soundlab (if they ever start selling 7809 and 7909s in england again, I remember last time I looked I couldn't get em anywhere, except ebay from china)
btw..cheers everyone for your help
Daz
My Site
Audio files: 69
PostPosted: Thu Apr 05, 2012 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Daz
"I get +15.1v and -14.8v. is this ok, do they both need to be the same?? do they both need to be bang on 15v?? "
That's not bad for 78 /79 regs .
Yes , an adjustable reg design would give fine tune 15V but unless your performing with ultra sensitive vco's and need critical tuning stabillity , that will be sound as a pound for diy fun synths.
Smile
Farnel do 9v +/- regs , or they did do .
Audio files: 69
PostPosted: Thu Apr 05, 2012 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry , just to add , i mis-read your transfomer voltage.
Monitor the voltage after the regulators when you connect the circuits up, the reg's may act funny under load with your 24vct xfrmr.
Audio files: 69
PostPosted: Thu Apr 05, 2012 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
If you get an 80VA 15/0 15/0 torroidal transformer that would future proof for quite a while & help reduce heat problems with regulators when you add more modules , it can become mind spinning planning a supply for a big system but your well on your way so far Smile .
Keep us updated .
crazeydazey
PostPosted: Mon Apr 09, 2012 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers mate, I might get me one of those torroidal transformers, then I know I'm good for a good few modules Smile
not gonna be able to put a load on the regs as I haven't completed anything yet Embarassed I have lots of unfinished stuff lying around (soundlab, WSG, rene schmitz VCO, korg delta VCF, plus others...) l that I need to get finished, just thought a PSU would be a good place to start
actually the above is a lie, I have made a nice ruby amp and Big Muff Pi pedal, but nothing synth related.
My Site
mps board
