  bingsatellites Mostly Ambient
 Forum index » DIY Hardware and Software » PAIA Equipment
PAiA Stringz'n'Thingz Noise Reduction
Page 1 of 1 [5 Posts]
stefanv
PostPosted: Sat Apr 07, 2012 9:36 am    Post subject: PAiA Stringz'n'Thingz Noise Reduction Reply with quote  Mark this post and the followings unread
Just under two years ago, I posted about my project to rejuvenate and expand an old PAiA Stringz'n'Thingz string synthesizer. The project went well, but in recent times the various unintended noises that it made started to annoy me, so I spent a few weeks tracking down some gremlins, and improving the circuitry to eliminate the BBD noise.
If anyone's interested, I've written it all up here:
Oh, the Noise! Noise! Noise! Noise! – Stringz’n'Thingz Revisited
Lessons learned?
- Everything can be improved, even old PAiA gear. Very Happy
- Never underestimate the capabilities of a wiring error.
Stefan Vorkoetter
http://www.stefanv.com
Dan Lavin
Audio files: 20
PostPosted: Tue Apr 10, 2012 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Stefan, nice read. I would recommend it to anyone doing heavy modding just for the lessons learned.
I don't remember my old Stringz being that noisy (at least not enough to bug me), but I do remember hearing weird little "artifacts" at the end of notes. I attributed them to the chorus board but I was probably getting a little LFO bleed-thru somehow. Since I sold it to an old friend back in '83-'84(?), I can only trust my memory of the thing. I do remember if I pressed the keys slowly enough, I could activate a VCA or noise gate and let those artifact sounds through without sounding the notes.
Synth DIY since 1977!
stefanv
PostPosted: Tue Apr 10, 2012 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dan.
Yeah, the original Stringz didn't have an "all strings off" mode, so they noise was nicely masked by the strings. But it did have dual-bus keyboard, one bus being used to key the particular notes, and the other to trigger the noise gate. If you carefully pressed a key where the noise gate contact closed first, you'd get the effect you describe (just like slowly pressing a key on a Hammond organ and hearing all nine harmonics start up separately).
Stefan Vorkoetter
Audio files: 27
PostPosted: Thu Apr 12, 2012 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very good article about your mods to the String'n'Thingz to make it work better-than-spec.
To intelligently mod something to make it work better-than-new is tremendously rewarding. Enjoyed reading about it.
Audio files: 27
PostPosted: Mon Apr 16, 2012 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a follow up now that I've had a chance to listen to the "before" and "after" recordings.
The quality improvement is dramatic -- clearly audible on the recordings even through my laptop's built-in speakers.
You've transformed the instrument into something quite useable.
cheers
Niio1
