new here, hello!! setting up with logic anyone..how??
Page 1 of 1 [12 Posts]
Laroque
PostPosted: Mon Apr 09, 2012 9:16 am    Post subject: new here, hello!! setting up with logic anyone..how?? Reply with quote  Mark this post and the followings unread
So, i have a multi instrument set for the a6 with correct names installed and its set to to control'alesis' logic seems to be selecting patches from the synth and hopefully they are the right ones, the lights change on the andromeda but the display stays the same, id like to know the patches/banks are the ones im selecting like all my other synths do supernova/proteus etc...what global info do i need to set on the A6?..could someone send me some pics or something of a clean setting of the soft knobs etc?..
also whats the score with the alesis what mode does it have to be in to select the right programmes?..does it need to be a certain mode?, like prog on most synths or performance etc,,,many thanks from a noob. Embarassed
Laroque
PostPosted: Wed Apr 11, 2012 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
BUMP please Andy heads help needed to stabilize this beast
Laroque
PostPosted: Mon Apr 16, 2012 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, this is a great Andromeda forum i must say,,its like being in a cave,,,all alone, sound of dripping water,,,,,,plink! Question Twisted Evil
Dougster
PostPosted: Mon Apr 16, 2012 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Honey didn't work, so you're trying vinegar?
Regards,
Doug
Once you start down the modular path, forever will it dominate your destiny!
Blue LEDs are evil.
Audio files: 116
G2 patch files: 317
PostPosted: Mon Apr 16, 2012 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or in other words, just like me ... "sorry, but I really don't know" Wink
Hope someone knowledgeable will stand up Laroque, it is a bit quiet here indeed ... and a belated welcome
Dougster
PostPosted: Mon Apr 16, 2012 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Heehee, I should have also said that I don't know. Wink I have an A6, but I'm not really sure what it is that you're trying to do...
Regards,
Doug
Blue LEDs are evil.
Laroque
PostPosted: Mon Apr 16, 2012 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
..this is really helping,,i like the tried honey vinegar thing, i might have to use that...but this is really not getting me anywhere,,logic has midi multi instruments in the nviroment wich control out board synths, i have the andromeda and the multi loaded, i just can get it to change patches via the DAW when its in multi timbral mix mode,,there is something i need to change somewhere ,,,thought someone on this might know,,,,,,,,'waits' Very Happy
Dougster
PostPosted: Mon Apr 16, 2012 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
ROFL, I'm such a hardware guy, I wasn't thinking that "logic" was the DAW program...!!! (Well either that or I'm just plain old.)
I've never tried to use my A6 with any software control, I have always used it standalone. I suppose I could try plugging it into my PC with Sonar and see what happens...
Regards,
Doug
Blue LEDs are evil.
Mefistophelees
PostPosted: Tue Apr 17, 2012 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you trying to get Logic to change patches within the Multi?
If that's the case I'm have no idea if that's even possible. You'd need to read the manual for both.
OTOH getting it to switch between different multiples should be just the same as changing between normal patches. - If you record MIDI in Logic and change patch on the A6 Logic will record it as MIDI. Play it back and the A6 will change as required.
http://soundcloud.com/Mefistophelees
Laroque
PostPosted: Thu May 03, 2012 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
thats exactly what i am trying to do, i have done it succesfully with every synth ive owned and im sure its possible with the a6, im aware it has to be on multi timbral mix mode, got that far and the patches change for each channel, but then stop after afew and remain on the same sound,,,
Laroque
PostPosted: Tue May 08, 2012 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
beyyyyummmmp
Laroque
PostPosted: Tue Jun 12, 2012 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
anyone ,,,please, im so nearly there with it, its almost changing via logic pro
Niio2
