CGS35 Steiner Filter not self oscillating
Page 1 of 1 [2 Posts]
bubzy
Audio files: 47
PostPosted: Wed Apr 18, 2012 3:40 am    Post subject: CGS35 Steiner Filter not self oscillating Reply with quote  Mark this post and the followings unread
I have bought a few of the cgs35 and find it to be an awesome filter, however i have built one in the past that self oscillated (i cannot remember the link but it was a pcb designed by a japanese guy).
is there anyway to modify the cgs35 to self oscillate? its kinda useful as an fm source.
_Richard_ Smile
jumunius
PostPosted: Wed Apr 18, 2012 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
From Ken's site:
"When using 2N3904 and 2N3906 I had to tweak the 2k2 in the resonance part of the circuit (connected to the emitter of the NPN in the amplifier) to compensate for transistor gain. A 15k across it brought it to the point where with the resonance full up, it was slightly ringing. A signal on the HP or LP inputs would then send it onto full oscillation, requiring the resonance to be backed right off to stop it, which is normal behavior for this design."
IIRC even though I used the spec'd transistors I needed to adjust this value as well.
-Jim
Niio2
