CONTACT MIC COMP
Page 1 of 1 [5 Posts]
Chestnut
PostPosted: Thu Apr 12, 2012 1:27 pm    Post subject: CONTACT MIC COMP
Subject description: Call for submissions: DUE 04/07 + info and rules:
This is call for submissions for Coupe Of Negation Theorem As Contact Trickery compilation by Brownian e/Motion(s)
This is a compilation about contact mics, a simple tool that can provide a wide variety of output. So we will keep the rules simple:
- Use a contact mic (piezoelectric transducer).
- Lossless file format (e.g. flac, wav, aiff, etc.).
- Email, Dropbox, whatever you like: brownian dot motion dot is dot noise at gmail dot com
- No time limit. Try to keep the file under 600MB or else it's going to get split and/or truncated.
- Track must be delivered by 17 April 2012 @ 2100 UTC-8.
- Tracks must be exclusive to this comp at the time of publishing. Feel free to put it on an album later, though.
- Track does not have to be new.
- You can use effects, post-processing, sampling, other instruments, multitracking, whatever. Just make sure a contact mic is part of the composition at minimum.
- It does not have to be a field recording, but really good ones are very cool.
- Compilation will be released on the Brownian e/Motion(s) Bandcamp page as e/BM(sss) with a by-sa license on 18 April 2012.
Just in case, here's how to make a contact mic:
http://home.earthlink.net/~erinys/contactmic.html
http://blog.makezine.com/2011/12/20/collins-lab-diy-contact-mic/ (with preamp)
http://www.zachpoff.com/diy-resources/alex-rice-piezo-preamplifier/ (with preamp)
http://leafcutterjohn.com/?p=1518 (literally grow your own!)
D.Miñoza
PostPosted: Sat Apr 14, 2012 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
+2
c[_]
soundcloud
relaxedmachinery
Chestnut
PostPosted: Sat Apr 14, 2012 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
hooray! c[_]
D.Miñoza
PostPosted: Wed Apr 18, 2012 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
its out!
Ayn and I have two tracks on this record. Check it out..
free download:
http://brownianmotion.bandcamp.com/album/coupe-of-negation-theorem-as-contact-trickery
soundcloud
relaxedmachinery
Chestnut
PostPosted: Wed Apr 18, 2012 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
INDEED c[_]
Niio1
