granoj
Posted: Fri Apr 20, 2012 3:54 pm Post subject:
seriously I always thought Lunettas where all about bleeps and buzzzz but this has certainly changed my way of thinking. If this was released on 12" I would play it, crazy stuff
Edit: are those samples unprocessed? |
Psyingo
Posted: Fri Apr 20, 2012 4:21 pm Post subject:
| granoj wrote: | | Edit: are those samples unprocessed? |
Yes, unprocessed, just straight into my sound card. |
efabric
Joined: Jan 05, 2012 Posts: 19 Location: Caen, France
Posted: Tue May 15, 2012 5:01 am Post subject:
Great work, and great sound !
I just wanted to ask for a little bit more informations about this :
| Quote: | 1x swing generator.
a swung clock is outputted at 1/4 the speed of the input clock. there are 5 values to be chosen via a rotary switch. I believe the values are 25%, 37.5%, 50%, 62.5% and 75%. reset in, clock in, and swung clock out.
I think this is your secret weapon, why you have a nice swing feeling in your rythms ! Is it true ?
Can you explain how this works ? _________________ My Scoopit DIY Synths and Schematics curation |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Tue May 15, 2012 5:38 am Post subject:
What chip is used for the swing generator? Schems? _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
Psyingo
Posted: Tue May 15, 2012 11:03 am Post subject:
| efabric wrote: | Great work, and great sound !
Can you explain how this works ? |
http://electro-music.com/forum/topic-53590.html |
JL
Posted: Thu Mar 07, 2013 10:05 pm Post subject:
| I know it's been almost a year since the last post on this thread, but I was wondering if the schematics were still available for this. The sound samples are amazing, and I'd really love to build something like this for myself. Thanks! |
L´Andratté
Joined: Sep 23, 2012 Posts: 12 Location: Hamburg, Germany
Posted: Sat Mar 09, 2013 3:05 am Post subject:
Sound samples -> 404 for me  |
Psyingo
Posted: Sat Mar 23, 2013 12:12 am Post subject:
| JL wrote: | | I know it's been almost a year since the last post on this thread, but I was wondering if the schematics were still available for this. The sound samples are amazing, and I'd really love to build something like this for myself. Thanks! |
check the original post, i reuploaded my files. |
Psyingo
| L´Andratté wrote: | Sound samples -> 404 for me  |
fixed, just for you. |
JL
Posted: Tue Mar 26, 2013 12:41 pm Post subject:
| This is amazing! Thank you very much! |
Psyingo
Posted: Tue Mar 26, 2013 12:44 pm Post subject:
| JL wrote: | | This is amazing! Thank you very much! |
no problem. i have pcbs that i've made that contain the 4 drum oscillators on it, if you are interested.. right here http://electro-music.com/forum/topic-52854.html
im working on getting a page set up to sell it from, in kit and pcb form. |
trav
Audio files: 9
Posted: Wed Mar 27, 2013 1:32 pm Post subject:
| Thanks for fixing your links, Psyingo. Good to hear/see this great machine. |
analog_backlash
Joined: Sep 04, 2012 Posts: 244 Location: Aldershot UK
Posted: Thu Apr 18, 2013 3:31 pm Post subject:
Hi Psyingo.
From your 4011 PCB thread:
| Psyingo wrote: | | baudrate wrote: | | The board and a surprise chip showed up today. Thanks a bunch! |
yeah, i was worried that it wouldnt work with certain chips, so i sent it with chips that i tested...
don't hesitate to shoot me a pm if you have any questions |
I've been playing with your original circuit on a breadboard and I've had rather variable results. Sometimes I get decent percussive sounds and other times constant low frequency oscillation (even with differences on two gates on the same 4011). I've tried several 4011s and failed to get everything working. Do you know what the problem with some chips is caused by, or which ones are likely to work? Of course, it's possible that I've just screwed up, but I've been checking/rechecking/rebuilding and I'm still having problems...
Thanks,
Gary
BTW: This is a great machine! |
Psyingo
Posted: Thu May 09, 2013 12:15 pm Post subject:
Hey, sorry for the belated reply.
one chip that i've found to work is the STMicroelectronics 4001BE (thats right, buffered...!)
I'm not certain why some chips work, and some don't. the internal circuit design of CMOS ic's varies wildly between manufacturers.
but ive found usually that if it works on one gate it works for the rest. although, im sure thats not the case for every ic.
i've gone between using 100k resistors and 47k resistors for R1/2, although i don't think this would cause the differences.
you could also try using 4069 NOTs as your gates instead of NAND/NOR... the only reason i used 4011/4001 was because thats what i had in the random cmos bag .
I do wish the chips werent so variable, but we are trying to build analog audio devices using stuff meant for digital logic. its not going to be ideal by any stretch.
FUN FACT: the suzuki omnichord OM-84 uses a similar set up to get its drums, as shown in this schematic http://www.voxinfinitus.net/~psyingo/OM-84_schematics.jpg at IC15. although,that one is a bridged-t, as opposed to a twin-t.
anyway... sorry i dont have any more concrete advice to give you. i have found that some ic's will give just humming, or distorted bips, or just clicks while some will give the proper percussive sound... :/ |
analog_backlash
Posted: Fri May 10, 2013 6:27 am Post subject:
Thanks for the reply Psyingo. I'll have to give the 4001B a go. I've got quite a few of those from 3 different manufacturers (but none are STM ). I did try 4069s out, but still had problems. I've been playing with the old Elektor twin-T design posted by YuSynth here:
http://electro-music.com/forum/viewtopic.php?highlight=twint&t=28541
This does work, but I'd like to try your idea again, as it has separate pitch and resonance control. I'll let you know if I have any success (and with what).
Gary |
Psyingo
Posted: Sat May 11, 2013 5:21 pm Post subject:
| analog_backlash wrote: | Thanks for the reply Psyingo. I'll have to give the 4001B a go. I've got quite a few of those from 3 different manufacturers (but none are STM ). I did try 4069s out, but still had problems. I've been playing with the old Elektor twin-T design posted by YuSynth here:
Gary |
here is the schematic i used to build the drums... maybe this will help more than my crude sketchbook one? http://www.voxinfinitus.net/~psyingo/electronics/schematics/rw_quadrum.png |
analog_backlash
Posted: Sun May 12, 2013 2:03 am Post subject:
Thanks a lot for that Psyingo - that's much easier to read than the sketchbook . I'll have another try at this circuit (probably tomorrow, as I'll be out most of today). As I said, I'll let you know how it goes.
Gary |
