knob_alchemist
Joined: Mar 03, 2012 Posts: 11 Location: Italy, Südtirol
Posted: Sun Apr 22, 2012 11:36 am Post subject:
Ok finished, one unit , works fine
....now I need a good panel for it....suggestions or a FPD panel for eurorack to share???
Thanks!!!! |
knob_alchemist
Posted: Mon Apr 23, 2012 9:49 am Post subject:
PS:: it's normal that in BOTH and FILTER mode there's a little hum? In VCA mode there isn't.... |
Posted: Mon Apr 23, 2012 10:53 pm Post subject:
knob_alchemist wrote: | PS:: it's normal that in BOTH and FILTER mode there's a little hum? In VCA mode there isn't.... |
will have to check this.
did you try to touch/move your switch wiring? does this change anything? _________________
Tech Buddy at Random*Source |
knob_alchemist
Posted: Tue Apr 24, 2012 12:07 pm Post subject:
No change touching the wiring...no one with this hum? |
knob_alchemist
Posted: Wed Apr 25, 2012 2:06 pm Post subject:
It seems that the hum is the signal of the VCO (more audible whe the VCO is at high range freq) in the LPG...I tried to set the trimmer but no change in the hum.... |
djthomaswhite
Posted: Sun Apr 29, 2012 8:25 am Post subject:
Hello builders and analog tweakers,
I am making some of the Resonant Lopass Gate (RLPG) circuit boards available again. I need to replace some that we're sadly lost in the shipments for the last batch and to replace my personal board stock for my own projects. I have received interest for additional boards recently so I will be taking orders to include extra boards in this replacement order.
If you want boards, please PayPal $15 per board to djthomaswhite@yahoo.com with "RLPG Order" in the subject line and I'll note your order. This cost per board includes shipping (global) via USPS. I always replace any boards lost in shipping, hence this order.
This board is the latest revision, but I will fix the IC ground issue in the mixer section thereby eliminating the need for the kludge to fix the board. Board orders are being accepted from now until May 13th with the new board order being placed on Monday the 14th. Boards take 2 weeks to arrive so orders won't start shipping until the week of May 28th. I know this delays delivery, but I order boards to demand and this method has worked well in the past.
I hope you find the news that I am making this limited run of Resonant Lopass Gate boards available to be good news. This project is a fun one and people from beginners to experts have enjoyed it. Please contact me with any questions or feedback directly at djthomaswhite@yahoo.com
Thank you,
Thomas White
Natural Rhythm Music
http://www.naturalrhythmmusic.com/lopass.html _________________ Thomas
www.naturalrhythmmusic.com/diy.html |
Toller
Posted: Mon Jun 04, 2012 2:49 pm Post subject:
Bleed |
I seem to have the same problem as knob_alchemist (see 2 posts above): the original signal is bleeding through (quietly, yet audible), even when the offset is all the way down and no cv fed in. Especially noticeable in both and filter mode.
Something wrong with the wiring / some kind of crosstalk maybe? Or is this normal? |
knob_alchemist
Posted: Wed Jun 06, 2012 2:53 pm Post subject:
Hi I've see your post and your PM... Your Problem is exactly the same of mine....Maybe is normal and depend from the VCOs??
I've not resolved the Problem, but is not a tragedy, I use a mixer to attenuate the signal of VCO (I use 2 A-110 in FM) and the bleeding is very quiet...
Suggestions? Maybe is normal? |
numbertalk
Posted: Wed Jun 06, 2012 3:44 pm Post subject:
Possibly related to the vactrol? If I'm understanding your issue I think this is normal for a vactrol, that it doesn't really turn all the way "off", if you know what I mean. |
Starspawn
Posted: Tue Jul 30, 2013 11:40 am Post subject:
Any left of the last run or a new one planned soon? |
Mongo1
Posted: Tue Aug 20, 2013 6:34 pm Post subject:
I think SynthCube.com has some...
Gary |
peng
Posted: Thu Dec 05, 2013 7:33 am Post subject:
My main question is this:
What is the "Deep" switch for?
I have read that it is for very large CV voltages.
But I don't get it.
What does it do to large CV voltages?
Anything that an input attenuator couldn't?
This version of the module has CV input attenuators so does that make the deep switch useless?
It practice, it seems to be.
If you have ever engaged this switch please explain why.
(I tried to post to Muff's but that forum is SNAFU lately...again) |
muziekzen
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
sneakthief
loydb
loydb
sneakthief
Posted: Mon Mar 16, 2015 10:29 am Post subject:
The four LPG's are simply wired individually according to the schematics. You will however need a simple mixer to mix the 4 outputs. This can be done with an op-amp like a TL072 and 7 resistors.
- use a 3PDT on-off-on switches for the VCA/VCF/VCA+VCF modes
- use 2 CV inputs: one directly in and the other with an attenuator
- cutoff and resonance pots are wired using the same orientation as the pot markings on the PCB
- re. mixer: use this, but ignore the red portion:
http://www.cgs.synth.net/modules/cgs04_mix.html _________________ Sneak-Thief - raw electrofunk |
loydb
sneakthief
Posted: Wed Mar 18, 2015 1:44 pm Post subject:
Re. mixing 4 LPG's: also consider using a simpler solution of 4x 10k resistors if you don't mind a signal level drop - which may not be an issue if you're mixing 4 loud-ish signals.
Connect one end of the resistor to the normalization pin of each of the LPG's audio output jacks, then connect all four other ends together at the main mix output jack. _________________ Sneak-Thief - raw electrofunk |
loydb
Ayab
Posted: Fri Oct 30, 2015 5:13 am Post subject:
Firstly thank you Thomas for this excellent project.
I noticed on someone's build (forget which) that the 1k resistors were white? Just realised must be heat shrink? Extra shielding?
Btw i really like the look of the acrylic panel by knob_alchemist. Does anyone know method of adding simple but uniform annotation to the (back in reverse would make hand painting a bit tricky but I could use a stencil - but v.time consuming).
I am really enjoying slowly comprehending some of this fascinating area (the surface!) which was a mystery only recently. I hope to maybe be of help to some beginners in the future. Sorry about the long post effect of reading the Open letter post - and yes I do have a day off today |
AKMacAddict
Joined: Jul 20, 2013 Posts: 1 Location: Anchorage, Alaska
Posted: Wed Nov 18, 2015 2:39 pm Post subject:
sneakthief wrote: | Re. mixing 4 LPG's: also consider using a simpler solution of 4x 10k resistors if you don't mind a signal level drop - which may not be an issue if you're mixing 4 loud-ish signals.
Connect one end of the resistor to the normalization pin of each of the LPG's audio output jacks, then connect all four other ends together at the main mix output jack. |
Really appreciate the information on the mixer circuit, as well as the above solution. I purchased a Quad, and afterwards was told it is missing the components for the mixer output. Apparently the reason was not being able to source the small mixer board (from CGS, or otherwise.)
Now I will be able to make this module "complete". Thanks! |
intercorni
Posted: Tue Mar 05, 2019 3:20 am Post subject:
Resonance Subject description: resonance starts too early |
Does anyone have the problem that the resonance starts too early?
At about one third of the way I'm already in the self-oscillation
Then the signal stops completely.
I use a linear potentiometer for the resonance.
And i try the mod from https://modularsynthesis.com/nrm/lopass/lopass.htm
But it is the same.
Maybe is a antilog pot better? |
intercorni
Posted: Thu Mar 14, 2019 1:18 am Post subject:
The trimm-pot TP1 does nothing - any suggestions?
The Offset-Pot works fine. |
