4051 ANY gate, more fun than a 4051 oscillator.
Page 2 of 3 [51 Posts]
attdestroyers
PostPosted: Tue Apr 24, 2012 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
JingleJoe wrote:
Banjo wrote:
Actually, the binary switches determine which decade, and the direction of the signal flow determine whether it is British, or American.
Thank you Joe for your explanations. One more question. What are your switches connected to?
The center of the sun. Laughing Which switches?
I think he's refering to the switches in your video of "the device." I was actually wondering the same thing.
PostPosted: Tue Apr 24, 2012 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think he was referring to more 60s British rock, this time being Pink Floyd with "Set The Controls For the Heart of the Sun" Smile
But seriously, yeah, I was wondering about what the switches did too...
JingleJoe
PostPosted: Tue Apr 24, 2012 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah the three little toggle switches in the corner? They change the gate configuration, however it is allways changing because of the LFOs, the switches just change which Y input the LFOs go to.
With them all set "up" the LFOs are connected to 1,2 and 4, giving the effect of ring modulation. Each can be switched between a different Y input, between 1 and 6, I remember I didn't use 0 and 7 but I don't know which switch switches to which Y input but I did put some thought into it so that each switch affected one oscillator more than the others.
PostPosted: Sun Apr 29, 2012 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I finally got to build this! After a week of slogging through my "list of circuits" to try, all of which failed or were disappointing, this circuit finally got to the top of the list, and it's quite CRAZY & FUN! Thanks for sharing this JingleJoe!
Since I'm still digging Cynosure's 4006+4040 triangle waveshaper [ http://www.electro-music.com/forum/topic-52443.html ] and still had it built on another breadboard, I ran the output of the 4051 ANY through it, and I like it.
I put three 1-minute snippets on my soundcloud, attempting to get some different sounds than what JingleJoe has shared...
CMOSnippet 027: Skistulogous by JamesSchid
CMOSnippet 028: Otilibous by JamesSchid
CMOSnippet 029: Podisrannious by JamesSchid
[ http://soundcloud.com/jamesschid if those inline players don't work.]
[Edit: corrected JingleJoe's username, sorry!]
JingleJoe
PostPosted: Sun Apr 29, 2012 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm very glad you like the results Very Happy I am allways happy to hear that someone likes my circuits Smile
However two things:
My username is just JingleJoe, not jingler Razz
Secondly, I can't listen to that first one, I have a headache and it is too high pitched so it is negatively lunetting my brain Sad
Nevertheless, some good sounds there Smile
PostPosted: Mon Apr 30, 2012 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
JingleJoe: ooops, sorry... my brain got crosswired for a moment with PHOBoS's Jingler box based on your other circuit.
I can't wait to get off work today and try a few more things with this one.
forshee
PostPosted: Mon Apr 30, 2012 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I love LUTs been thinking of writing this post for ages. If the switches switch between V+ and an input with a tie down you can get just about anything. Been working on a 5U version of this for some time lots of possibilities. Add some jk flip flops and you should be able to do just about anything. Make a few thousand of those and you've got an FPGA.
Banjo
PostPosted: Tue May 01, 2012 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry I haven't replied, but life gets in the way sometimes. I figured that the switches had something to do with the gates. I will keep an eye on this thread for inspiration when its time to work with the 4051 again. For now, I am trying to figure out my next project. I decided to try to do it in Reaktor first to work out the kinks. It's much better to spend an hour or two tweekng and getting it functional, than spending several hours soldering and finding out that it does not work.
Its time to build a mixer/signal router/control panel. I want to send some of the audio from my DIY synth into Reaktor , and play with it there. At least it gives me a good excuse to finally go through all of the tutorials on the program.
I will have to label one of the panels or knobs, the heart of the sun!!
Inventor
Audio files: 256
PostPosted: Wed May 02, 2012 12:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I was listening to a rock and roll playlist when i encountered this thread again (after a few days hiatus in second life), and being lazy like i am i decided to just play the lunettas simultaneously with the rock. Success! Listen to "Another one Bites the Dust" by Queen along with RingMad's samples - good combination!
Which brings up an important point in listening. A lot of what we create with Lunettas are sort of missing something. Let's face facts: it is well known that Lunettas usually are way out there big time! So it only makes sense to comingle them with other music. Other new music, other conventional music, other Beethoven, whatever!
Give it a try - you'll like it!
Les
JingleJoe
PostPosted: Wed May 02, 2012 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
In the same vein as inventors suggestion there; Lunettas will be the backing in my future band, but not the core of the music. Smile
I'm modifying an old device which never sold with a 4051 ANY gate today, results coming soon!
Mikmo
PostPosted: Wed May 02, 2012 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
This device has immediately been propagated to a high place on my "modules to build list"
If i understand it right, you have 3 inputs (the LFO's) on the "Y side", the toggle switches each switch one LFO between 2 different Y inputs - right ?
Do you have pull down / up resistors on the Y inputs the LFO's are connected to ?
Have you pulled the 0 and 7 Y inputs high or low or just left them floating?
Stay Cool
Mikael
http://www.mikmo.dk
PostPosted: Wed May 02, 2012 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Inventor posted a nice clear schematic for this circuit over in his boolean sequencer thread... http://electro-music.com/forum/topic-41367.html ( look for "BS LUT 1.jpg")
But yesterday in playing around with it, I have some questions, which I was having trouble deciding if I should post here or in that thread. So here goes:
1. What purpose do the 10K resistors serve going into the DIP switch?
2. Is there any danger if one has a switch open (i.e. a logic 1 is flowing through it) and a squarewave going into the same line?
3. If I don't use any oscillators on the Y pins, and just open a few switches, it seems almost nothing gets through... i.e. I only faintly hear any audio from my A,B,C inputs coming through. As soon as I plug an oscillator into at least one Y pin, then I get something. [I admit I didn't sit down yet and figure out the particular truth table, which I suspect might have something to do with it]
James.
Mikmo
PostPosted: Wed May 02, 2012 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
My guess is that the 10K resistor is there to limit current running into the 4051 x inputs.
Stay Cool
Mikael
http://www.mikmo.dk
Inventor
Audio files: 256
PostPosted: Wed May 02, 2012 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
RingMad, the 10k resistors are the pull-up resistors, while the 100k resistors are pull-down. When the switch is in the open position the 100k resistor pulls the input down to ground, and when the seitch is closed a voltage divider between the 100k and the 10k forms, giving us appoximately 90% of Vdd.
This arrangement is one way to accomplish the state switching when you only have one spst switch (eight of those on an 8-DIP package). The only problem here is that if the mux is an analog mux, which i believe this one is, then the output impedance is 100k for logic zero and about 9k for logic one.
That would affect the aggregation of the signals into a stim voltage so buffering is desired. I just put an additional 100k resistor at the output for now since there is no room on the board for a buffer, but I'm thinking I need a 5VDC regulator anyway, so i might reduce the board to only 3 circuits and add the buffers. Better save than sorry.
Les
p.s. we now bring you back to your regularly scheduled thread!
PostPosted: Wed May 02, 2012 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to derail this thread with more newbie-type questions, but perhaps the info might be useful to others.
Yes, the datasheet says the 4051 is analog. I don't see anything about the output impedance.
What do you mean by "stim voltage"? As for buffering, you mean at the output? This 100k resistor at the output, that's inline or to ground?
I figured out part of my question #3 above... the DIP switches alone do nothing if the output of the 4051 is connected to Cynosure's waveshaper circuit I was using. If I take my output directly from the 4051, they work fine. This is sad... I really like the waveshaper. I don't understand why having it there is a problem.
James
Inventor
Audio files: 256
PostPosted: Thu May 03, 2012 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
James
RingMad, the answer to your conundrum and mine as well is buffering. Since the part is analog, what it has internally is something known as a pass gate made of two transistors, a P transistor and an N transistor with opposite values applied. Sized correctly, these become a nearly ideal analog switch. That means that whatever impedance is presented to the input appears at the output.
In this case we are applying an input impedance of either 100k (to ground) or 9k (to Vdd), so that is what appears at the output. I don't know what you are wiring to this output, but it will affect the voltage division at the input depending on what it is. As always, remember to consider the whole circuit. Do not assume that an unbuffered output is not affected by it's load. Here y ou have connected something that is reaching back through the analog switch and affecting the input circuitry, and therefore the output value. With buffering, however, this is not an issue.
As for the stim voltage, my Boolean sequencer is designed to drive the inputs of a Karplus Strong board which has a stim pulse, that is all. I hope that explanation helped, and please ask again if you have any more questions.
Les
PostPosted: Thu May 03, 2012 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, buffering fixed the problem, thanks Les!
And, I finally figured out what you meant by "stim voltage"... stimulation!
Still having lots of fun with this circuit, making several recordings. Probably will put more on my soundcloud soon. Definitely this guy will be part of my suitcase Lunetta. And maybe even a box to itself.
James.
JingleJoe
PostPosted: Sat May 05, 2012 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I feel the need to mention, as it is relevant to some of your queries chaps, that I seem to recall that the resistance of the Y inputs to X were stated on the datasheet and changed a little for different supply voltages. I think they were about 300 ohms in general but check the datasheets, I may be wrong.
Ringmad, to elaborate on your 3 earlier questions, the 4051 is like switches, if nothing is connected it's literally like having a bit of wire that goes nowhere Smile You need to add a pull down/up resistor or some kind of voltage. Remember also that logic 1 is acctually a voltage and connecting it directly to another one would do strange and possibly explodey things, I would advise you mix them passively through 100k resistors or through a gate; e.g. a diode OR gate.
PostPosted: Sun May 13, 2012 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, nothing's exploded yet, except the number of recordings I made using this ANY gate (and usually going through Cynosure's triangle waveshaper)! I think it's up to 24 now, which is the most I've done for any Lunetta module.
I've selected and edited some of the best and thus there are 5 new CMOSnippets on my soundcloud if anyone cares to listen... http://soundcloud.com/jamesschid
Thanks muchly again JingleJoe!
James
JingleJoe
PostPosted: Sun May 13, 2012 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
They all sound great Very Happy I could hear my ANY gate in a few of them Wink Carry on the good work, I'll say it again, I am always happy to provide weird sound circuits Wink
Audio files: 254
PostPosted: Thu Apr 18, 2013 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm currently turning a toy keyboard into a synth And I need to mix two audio signals together.
Because they're squares I can mix them with logic instead of just using a standard resistor mixer.
So I want an XOR/OR/AND mixer selectable with a switch and using a mux for this seems to me the
easiest way. The first version I drew up used a double 3 pole switch. but I got it down to just a
single toggle switch with center position. I remembered jinglejoe's ANY gate also used a mux allthough
I wasn't sure if it would be the same configuration. So I took a look at it and it is indeed a similar
setup Very Happy
This version uses a CD4052 instead of a CD4051 since I only have 2 signals. I used the other half to
make the equivalent of a (non-inverting) summing mixer with a gain of 0.5. But I'm not sure yet if I
will do this in the definite version. You could make a double digital version and then you don't need
the opamps and could use some logic gates to buffer the signal . If you do use opamps you don't have to
power them with -/+ 12V, but you can use the same voltage you use for the CD4052.
Xor/Or/And + analog mixer with a CD4052
 Filesize:  28.59 KB
 Viewed:  12 Time(s)
http://www.acidtrash.com/
efabric
PostPosted: Tue Apr 23, 2013 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I feel like you're feeding the beast the wrong way...
Isn't the 4051 a digitally controlled switch ?
If you feed Y inputs with eight tuned oscillators like this :
Y0 : C
Y1 : D
Y2 : E
Y3 : F
Y4 : G
Y5 : A
Y6 : B
Y7 : Octave C, or no note at all (ground)
(of any combination of eight loved vintage 60's bands, 8 tape tracks, etc.)
And your A, B, and C inputs with LFOs,
You can collect at output X a random melody generator, or random cut playlist, or track selector...
If you feed A, B, and C with audio frequencies, your multiplexor is too much out of control, and displays only an audio fragment of a lfo...
My Scoopit DIY Synths and Schematics curation
JingleJoe
PostPosted: Tue Apr 23, 2013 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
efrabic, you have missed the point completely.
go back, read everything again.
Phobos, you have not missed the point at all, you have harnessed the very core of the idea.
efabric
PostPosted: Tue Apr 23, 2013 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think I missed the point. Perhaps only the use and effect of your three switches ?
CMOSnippet 028: Otilibous by JamesSchid illustrates what I said. I haven't heard it before cause internet restrictions.
No need to read everything twice.
Another Idea : If you connect Y points with a packed resistor array , the X output can also send a random (or digitally controlled) Control Voltage to feed another VCO...
Resistor arrays contains matched resistors, simple to solder in parallel and easy to find in electronics garbadge...
Draal
PostPosted: Tue Apr 23, 2013 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was going through my parts drawer (very untidy at the moment) and I found a few spare 4051's and 4052's. Now I have something cool to do with them that I wasn't expecting... Cool
thanks JingleJoe and PHOboS
Zontar Prevails!
