Have pcb, ready to build
Page 1 of 1 [6 Posts]
KnobHell
PostPosted: Wed Apr 04, 2012 7:42 pm    Post subject: Have pcb, ready to build Reply with quote  Mark this post and the followings unread
I have a Klee board set, and a Bridechamber panel. I just ordered the pcb parts.
Before I start building are there any recommended mods that are good to have?
Cheers!
len
theglyph
PostPosted: Wed Apr 18, 2012 11:37 am    Post subject: Re: Have pcb, ready to build Reply with quote  Mark this post and the followings unread
KnobHell wrote:
Cheers!
len
Yes, Modify your mindset of how a sequencer works. Wink
Audio files: 27
PostPosted: Wed Apr 18, 2012 11:45 am    Post subject: Re: Have pcb, ready to build Reply with quote  Mark this post and the followings unread
KnobHell wrote:
Cheers!
len
I've built two Klee Sequencers and I suggest that you build it without mods. This will make troubleshooting (which is likely) much easier. You can always mod it after you get it working.
Since you plan to mod it, leave enough slack in the cables from the PCBs to the panel so that you can easily remove, maneuver, and service the PCBs.
And, yes... the Klee can be used as a common 8x2 or 16x1 sequencer however its features make it more of a real-time compositional tool.
KnobHell
PostPosted: Wed Apr 18, 2012 12:15 pm    Post subject: Re: Have pcb, ready to build Reply with quote  Mark this post and the followings unread
Cool, that's good to know.
Thanks for the reply.
len
theglyph wrote:
KnobHell wrote:
Cheers!
len
theglyph
PostPosted: Wed Apr 18, 2012 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm with Kevin and don't forget that mods will likely require additions to the front panel so if you plan on doing mods leave some room on your panel for extra drilling.
Audio files: 22
PostPosted: Wed May 02, 2012 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Not so much a MOD but a suggetion to add an option.
Just my opinion but definitely add the variable voltage input option in place of the fixed CV position "8" on your CV scale selector.
Bill
