Let's see your Lunetta!
Page 16 of 22 [526 Posts]
Goto page: Previous 1, 2, 3, ..., 14, 15, 16, 17, 18, 19, 20, 21, 22 Next
PostPosted: Thu Oct 27, 2011 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
kaputtpanzer - that is a beautiful looking lunetta. Nice job on the design!
Audio files: 213
PostPosted: Fri Oct 28, 2011 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
kaputtpanzer wrote:
The latest thing:
wave wave wave
mako
PostPosted: Sun Feb 26, 2012 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
hi all,
I finished my new project and ts is basically a modified version of the 'heterodyne space explorer' by beavis audio, the only things i have changed are some potentiometers, I just left them completely out in the mixing section and I changed one of the pots by the oscillators with a switch.
I'm already happy with the sounds but not yet with the looks...
somebody has any sugestions on how to put it in a good looking box/enclousure?
(I will add some nice control knobs, I have already ordered them)
http://www.youtube.com/watch?v=WNHdlKYqE6o&feature=youtu.be
garcho
PostPosted: Sun Feb 26, 2012 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice job! any thoughts about a user interface?
"The life of a repo man is always intense."
garcho
PostPosted: Sun Feb 26, 2012 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
The best place to look is Let's See Your Lunettas, the thread you're reading right now.
cigar-style boxes:
cheap, phony 'pelican briefcases':
cheap radio shack plastic enclosures:
metal guitar 'stompbox' enclosures:
Small Bear
Pedal Parts Plus
mako
PostPosted: Mon Feb 27, 2012 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks garcho, these things all look great. I think it will be some kind of homemade enclousure in the cigar box style for me! Smile
garcho
PostPosted: Mon Feb 27, 2012 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Make sure your pots' and jacks' shafts are long enough to go through however thick the wood in your cigar box is, before you start drilling.
mako
PostPosted: Tue Feb 28, 2012 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the tip, I was already looking for a cigar box, but I came out on a good looking empty wine crate, but now I see the wood is way too think for my pots, switches and jacks... So I will have to keep on searching...
garcho
PostPosted: Tue Feb 28, 2012 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you're willing to spend a few extra dollars, you can order long shaft pots that will fit through many inches of anything. Same with jacks, but I haven't seen many switches with long shafts.
or
If you use a wide spade drill bit, say 1" or so, you can bore a 5/16" hole for your pots and have a 1" circle faux-routed about half way through (careful with that drill Eugene), which will be then thin enough for your pot's shaft to poke through enough to bolt it into place. As you can tell, my handyman vocab is lacking, so if this doesn't make any sense, I can post a picture of an example for you. The only issue is you will need more space between pots, to accommodate the 1" circle routing. Remember to do the faux-routing (won't be faux if you have a drill press) first, THEN the standard twist bit drilling. If you do it the other way around, the spade bit will flail all over and give you a rough, curvy triangle instead of a perty circle.
Wine boxes look really nice and are sturdy, so I suggest trying to make it work somehow if you can.
mako
PostPosted: Wed Feb 29, 2012 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, I think I get what you are saying, just drill very large holes so the pots fit in them entirely and then a smaller hole in the middle of the big hole for the shaft, right?
It sounds great if I could do it like this. I will definetely try it if I find the right tools for it. And if I use the wine crate, i will still have some spare room to put in another project in the future so I think I will make it like this.
Thanks a lot for all this usefull info Very Happy
attdestroyers
PostPosted: Thu Apr 26, 2012 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
My Lunetta... 3 modules left to build.
 Filesize:  89.9 KB
 Viewed:  2256 Time(s)
 Filesize:  100.03 KB
 Viewed:  2239 Time(s)
garcho
PostPosted: Thu Apr 26, 2012 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
bravo!
Audio files: 705
PostPosted: Fri Apr 27, 2012 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
looks gorgeous thumleft
I guess those cinch connectors are for the power supply, nice.
but it does make me wonder why not use one connector for both + and - ?
attdestroyers
PostPosted: Fri Apr 27, 2012 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Coulda woulda shoulda. haha
I started out my little electronics adventure as a circuit bender and i used the same RCA style connectors for patchbays all the time. I started connecting one wire to both terminals back then because i only needed one wire between points, i didn't have to totally plug it all the way in when searching for bends, and i had better connectivity that way... So I guess I did it like that just out of habit
Draal
PostPosted: Fri Apr 27, 2012 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Too sweet Cool
Looking forward to seeing/hearing it speak its truth.
Zontar Prevails!
attdestroyers
PostPosted: Sat Apr 28, 2012 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Draal wrote:
Too sweet Cool
Thank you! No really, your blog has been a great resource for me.
Youll have to give me time to finish it before i post sound clips.
Draal
PostPosted: Wed May 02, 2012 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a short video of my machine . Outputs of a 4040 and 4094 are connected to the 4512 data inputs. The 4512's ABC controllers are 3 different oscillators but you can mix that up with any logic really. The output pin of the 4512 goes to my pitch tracker which creates some interesting sweeps.
Zontar Prevails!
kaputtpanzer
Audio files: 15
PostPosted: Thu May 03, 2012 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Lil' techno machine! Cool
Draal
PostPosted: Thu May 03, 2012 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Me likey!
Zontar Prevails!
Draal
PostPosted: Thu May 03, 2012 1:14 pm    Post subject:
Subject description: More More More
I had a free moment:
Excuse the mad labs' state of confusion. Laughing
Zontar Prevails!
-minus-
PostPosted: Thu May 03, 2012 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
You have been busy Draal. Where do you get your banana leads from?
Mikmo
PostPosted: Thu May 03, 2012 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see your kidd in there Smile
How old is he now ?
Stay Cool
Mikael
http://www.mikmo.dk
Draal
PostPosted: Thu May 03, 2012 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
@Minus - Yeah, I have been busy keeping up with my 2 sons, which is getting to be a challenge. But childhood only comes once, so I'm enjoying it. I purchased those cords from evil bay and I can't think of the seller offhand.
I'll see if I can find out who they were. I think I bought 10 for 20 dollars? They have a great rubbery feel and have put up with my abuse very well.
@Mikmo - He likes my mancave, which proves it's genetic Cool . Adam is going to be 2 years old in July. Which makes this hobby about as old for me.
Zontar Prevails!
Draal
PostPosted: Thu May 03, 2012 3:49 pm    Post subject:
Subject description: Still sells EMP'
@minus - Well don't that beat all. There's my seller...ships worldwide too.
http://www.ebay.com/itm/VOLTREX-STD-STCKING-BANANA-PLUG-28-10PCS-PER-LOT-/170708899710?pt=LH_DefaultDomain_0&hash=item27bf0b177e#ht_582wt_689
Good price for ten nanners.
Zontar Prevails!
-minus-
PostPosted: Thu May 03, 2012 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the link. Shipping is the killer though. $17.95 US to Australia. I may have to look elsewhere. Sad
