Getting started with analog modular
Page 1 of 1 [22 Posts]
Dogue
PostPosted: Thu May 03, 2012 9:20 am    Post subject: Getting started with analog modular Reply with quote  Mark this post and the followings unread
I have a lot of experience with software synthesis (Max/MSP, Reaktor, etc.) and some with hardware (physical controllers, effects pedals, Lunettas), but I am now interested in putting together an analog modular system and looking for advice.
I have several design goals:
1) Small and portable.
2) Modular and able to interface with computer, Lunettas, mic/instrument inputs, physical controllers (touchplates, etc).
3) Inexpensive.
4) DIY modules not overly complex or time-consuming to build.
5) Start with basics and expand as I go.
Obviously, some balances will need to be struck. For instance, while going the DIY route will often help keep costs down, I am willing to purchase manufactured modules if doing otherwise would be too difficult or time-consuming. While I have a decent amount of experience soldering and building from schematics, I am no expert.
So, do you have advice for how I should get started?
Are there particular modules I should begin with, whether DIY or manufactured? I've been looking at Ken Stone's, Ray Wilson's, and PAiA's offerings, for instance; any recommendations?
How should I design it such that I'll be able to interface with computer, Lunettas, etc.?
Thanks a lot!
Dougster
PostPosted: Thu May 03, 2012 9:08 pm    Post subject: Re: Getting started with analog modular Reply with quote  Mark this post and the followings unread
RUN AWAY!!! (See my signature quote about destiny...)
I think you're an optimist. "Often" will probably not apply to keeping costs down. DIY has always been more expensive for me, especially compared to buying used premade modules. When you take into account all aspects of DIY, you probably won't be able to justify DIY for low costs. The real advantages of DIY are that you get to create exactly what you want and you get to learn a lot along the way.
It's a bit dated now, but if you're going to embrace the addiction, you might check out my old web page about this stuff at http://www.analognotes.com and in particular, I'd suggest checking out Doepfer and Blacet. Doepfer has the widest variety of modules and, in my experience, Blacet is the most reliable shipper in the business. My own system is split between Blacet and Synth Tech. I love 5U modules, but they are significantly larger than the 3U stuff, so they're probably too big for your needs...
Regards,
Doug
Once you start down the modular path, forever will it dominate your destiny!
Every DIY person should own a copy of Electronotes: http://electronotes.netfirms.com
Blue LEDs are evil.
Dogue
PostPosted: Fri May 04, 2012 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply and the advice. You are probably correct -- this would not be the first time I've been accused of being an optimist. Smile
What, in your experience, has in general caused DIY modules to be more expensive? From my experience with effects pedals and small noisemakers, the enclosures and hardware often ended up costing much more than the parts.
How about the cost of modules available in kit form, say Elby's CGS modules? It seems that they are relatively economical.
There are certainly some unique things I'd like to build that are not commercially available, or not commercially available within my budget, but I likely can find many modules available.
At the least, I suppose I should first decide on a mounting system and a power supply.
Also, I was interested in using banana plugs so that I could have multiple sources going to a single destination, although many of the more economical units use 1/8" or 1/4" jacks. How easily could these be modified to accept banana plugs instead?
Thanks again.
Audio files: 27
PostPosted: Fri May 04, 2012 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
The biggest expense in DIY are the control panels: the panels themselves, pots, knobs, and jacks. If you want to design your own panels and have them commercially etched, plan to spend big bucks.
However, if you can learn to build and label your own panels, this saves a good deal of money. There are numerous techniques for creating panels from aluminum, plexiglass, and other materials.
Of the companies you mentioned, I would suggest to start with MFOS (Ray Wilson) simply because the supporting documentation is excellent. Having said that, I really like Ken Stone's modules however they may not be as easy for a beginner. Also, consider Yusynth, too -- the designs and docs are excellent -- and don't shy away from etching your own PCBs. It is not difficult and it is a lot of fun to etch and drill your own.
PostPosted: Fri May 04, 2012 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Two things have kept me leery of etching PCBs...(not to hijack the thread)
1) disposal of nasty chemicals (even though I've heard that it can be "cleaned" and reused, eventually that cycle will end). Everyone says "proper disposal" and nobody says what that disposal actually looks like.
2) experience with PCB layout software.
#2 has an obvious resolution (just do it and learn! Smile ), but #1 concerns me.
Anyone have any suggestions? I'll be happy to open a separate thread if the thought is that the answers will be long and involved. But searching here and in google have not really turned up anything I can say leaves me really cozy feeling.
Audio files: 27
PostPosted: Fri May 04, 2012 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Since Yusynth has the PCBs available as PDF files, one doesn't need to design one's own PCBs. Also, many of the Yusynth PCBs are availabe at Bridechamber, too.
I'm still on my first bottle of etchant -- it seems to last a long time (I've etched dozen's of PCBs). In our community, there is a place (can't remember the name) where one can take chemicals, paint, etc... for proper disposal.
Dougster
PostPosted: Sun May 06, 2012 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Heehee, cool. Here's hoping you never lose that!
Other posters have pointed out the cost of panels, enclosures and mechanical parts. That's the biggest part of it, but you'll also spend a lot of time sourcing parts and dealing with a variety of vendors. The older you get, the more you realize your time is valuable. Do you want to spend your time making synths or making music? (Heehee, I've turned into a collector/designer/builder/manufacturer myself. I haven't composed any new music in several years. I should also mention that I have two teenage kids that have impeded my progress in the last several years...)
There aren't all that many complete kits around, at least relative to the total number of designs. Elby has a good repuation and I'll repeat my suggestion to check out Blacet. Blacet kits are reasonably priced and ship quickly. He also has a nice power supply and mounting rack. A bit pricey, but worth it to me for the peace of mind. You might also check out PAiA. They're not fancy, but they've been around for a very long time and the price is hard to beat...
Yes, that is the real reason to go DIY. I think it was Thomas Henry who said that you can't make things cheaper, but you can make things better. BTW, have you checked out the Muffwiggler forum?
Heehee, that is easier said than done! It is very hard to keep to a single system. If you're like me, you'll end up with 3U and 5U tall modules and 1U and 2U full width boxes as well as all manner of desktop and floor boxes! I'm personally a 5U fan, but 5U takes up considerably more space and costs more. There are two main 3U specifications, frac rack and euro rack. I'm in the US, so I found frac rack first. There are some unique frac rack modules available, but you'll find that there is a larger variety of euro rack modules. This may seem silly to think about, but I like the uniformity of the frac rack modules. There are usually only half width and full width modules, with the occasional dual or triple width module. Euro modules come in a lot of different widths, so you can fit a lot more modules in the same space, but you don't have that consistent look. The down side of frac rack modules is that IMHO they're a bit more amateur looking...
I don't use bananas, but if I understand correctly, you need to make sure all your modules are properly grounded together because the bananas only connect the signal where the 1/8" and 1/4" cables connect both signal and ground. I use a lot of mults in my rack for distribution and most of them have some kind of attenuator or logic so that I can control levels, invert signals, etc...
So, let me ask, what are you trying to accomplish and/or create with your modular? Do you want to make a system that generates sound or manipulates it? Do you want to create something that you play with a keyboard or other controller? Or do you want to create a standalone sound generator that has self running patches? Or do you want to use other sound makers as input and manipulate those sounds?
Regards,
Doug
Blue LEDs are evil.
Dougster
PostPosted: Sun May 06, 2012 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Contact the MagSmoke guys and see if they still have copies of the Thomas Henry DVD. In it, Thomas explains how he builds everything, including a demonstration of etching boards.
On the flip side, I have never etched my own boards, and don't believe I ever will. There are some great PCB layout programs out there, and with board houses like Gold Phoenix and Olimex, you can get professional pcbs for not a lot of money...
Regards,
Doug
Blue LEDs are evil.
PostPosted: Sun May 06, 2012 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually I do have the TH DVD, I hadn't gotten to that part... I sat and watched through most of it in one night and my wife kept rolling her eyes at me Very Happy.
Thanks for the reminder, I'll try to watch it tonight. Maybe I can convince her that it's better, at least I'll be out of my cave Smile
Tim Servo
PostPosted: Mon May 07, 2012 5:36 pm    Post subject: Getting started with analog modular Reply with quote  Mark this post and the followings unread
LOL, I get the same reaction from my spousal unit.
Tim ("Oh of course not, Ferric Chloride doesn't stain... much.") Servo
Dogue
PostPosted: Wed May 09, 2012 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought my reply to this posted, but it looks like it didn't!
Anyways, thanks for all the replies.
I've been recently reconceptualizing my approach to instruments/sounds-makers, and I am now conceiving of everything to be in some way modular, so that I can interface basically everything I do -- piano, analog modules, Max/MSP patches, Lunetta-type circuits, controllers, etc. -- together. So while I'm getting some "basics" in analog modules, many of the things I'm planning on starting with are the Buchla/Serge-type rather than Moog-type, and I'm trying not to overlap too much with what is easy to do in Max/MSP.
I did find the muffwigglers forum -- thanks!
For the time being I've decided to go with Eurorack, and I've ordered a bunch of CGS and Elby kits and also panels for them.
I have not yet procured a case or power supply. I'm thinking of going for something inexpensive and DIY for now with the case, and perhaps keeping it small enough so that eventually I can put it in a Pelican carry-on case if I get to the point that I am touring with the rig. I'm also considering going with a Tiptop uZeus or similar small power supply.
One thing I do want to do is adapt some of the Nic Collins/Lunetta-type circuits to work in an analog modular setup. So, it seems I should use a comparator circuit at the input of these, as suggested here:
http://electro-music.com/forum/post-211004.html#211004
Any more advice on this?
Thanks again.
mrmrshoes
PostPosted: Thu May 10, 2012 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
A midi note 2 trigger/gate convertor might interest you seen that you are using Max. I've built one with an arduino. It's a pretty simple circuit.
I believe someone has posted a similar circuit (with Layout and Code) to the forum. Can't remember where. If i find it i'll post it.
Yeah man that's how i'm approaching things at the minute. I'm on building a CMOS based machine as well as a patched out MFOS sound lab mini. So i'm finding this thread useful. I've also used Max MSP a bit (Need to study more)
For CMOS inputs you could add diodes to protect against Neg Voltages.
Please keep the tip's coming
I've also been building a DIY euro rack case and researching a DIY power supply (Still haven't had time to build it yet. I'm using a MFOS wall Wart PSU as a stop gap). here is a PDF of a post i made for another forum.
DIY-Euro-Rack.pdf
 Filename:  DIY-Euro-Rack.pdf
 Filesize:  400.92 KB
 Downloaded:  591 Time(s)
PostPosted: Thu May 10, 2012 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
That would be me Smile
http://electro-music.com/forum/topic-52722.html
More code than circuits, but I adapted the Thomas Henry MTS-100 circuit as described in that thread.
The original TH article from Nuts & Volts is:
http://www.nutsvolts.com/uploads/magazine_downloads/11/December%201997%20Thomas%20Henry%20-%20Build%20Your%20Own%20MIDI-to-Synthesizer%20Interface.pdf
In retrospect, I wish I had thought to provide a velocity output of some sort instead of the pitch bend, and/or gone ahead and found a way to implement the pitch bend so I could use it for example with a computer-based midi controller. Once I have a fully noise-making setup, I will probably go back and adjust. A lot of commentary I've seen online about MIDI->CV btw suggests using a higher resolution DAC if you want to do pitch bending....
bubzy
Audio files: 48
PostPosted: Fri May 11, 2012 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
dont be afraid of etching your own... its easy after a few goes. i etch practically all of my own pcbs although i do use perf for one offs. the etchant wont kill you (unless you drink or inject it, and maybe not even then) but it can make your clothes/hands/worktop/dog yellow for sometime, ive had it on my hands and it washes off after a couple of days, havent got it on any clothes that i care about.
if you do decide to follow that route a couple of tips:
1: make sure the copper clad is CLEAN, no fingerprints allowed.
2: make sure the copper clad is VERY HOT, BEFORE you put the toner sheet anywhere near it.
3: apply even pressure all the way across the board and keep moving the iron, do this for a couple of minutes (best to use an old iron that your wife doesnt want to use for clothes again)
4: dont rub the paper off quickly, let it soak for a few minutes and then gently rub it off
5: warm the etchant (bain marie etc) i have used the microwave before but decided that i'd be better off not doing that.
6: keep the board moving inside the etchant, i "dip" it in the solution, this allows the old oxidised copper to wash off and the ferric chloride to start oxidising underneath.
after that just give it a rinse.
sorry to "hijack" this thread but i would like to dispel the fears about home etching. its actually not hard (seriously, I can do it....)
_Richard_ Smile
PostPosted: Fri May 11, 2012 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I appreciate it buzby...I think my biggest challenge is going to find a way to get a toner-based print, as I only have inkjets, and not really any convenient way to print to a laser printer...
Dougster
PostPosted: Fri May 11, 2012 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, to continue the hijack Wink Laughing at what point do you guys decide that perf board isn't good enough and that you have to etch a board? Seems like a pain to have to drill all the holes after etching. At the same time, I would tend to think that if you were doing surface mount, it would be a good thing...
Regards,
Doug (I like having soldermask and silkscreen myself...)
Blue LEDs are evil.
bubzy
Audio files: 48
PostPosted: Fri May 11, 2012 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
doug : i dont do a tremendous amount of etching at the moment, although we "decide to etch" when someone else has done all the hard work of designing a board for us Smile then drilling a few holes doesnt seem so bad.
i do like to share my designs too for other people to benefit, additionally if im going to make multiples of one circuit i find that designing and etching a board can save a bit of time in the end. Smile
elmegil : yeah its gonna be a bummer without a laser printer (possibly a photocopier at a library or such would do it....if you can get the to let you feed glossy magazine paper through their coper Very Happy )
_Richard_ Smile
Dogue
PostPosted: Fri May 11, 2012 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work, mrmrshoes!
For the time being I am planning on building a case out of this tool case:
http://www.harborfreight.com/hand-tools/tool-boxes/18-inch-x-12-3-4-quarter-inch-x-6-inch-aluminum-case-39196.html
I will probably just put in wood for rails for now. I'm planning using a uZeus power supply. The tool case should be small enough that I can eventually put it inside a Pelican case for travel.
Do you have any thoughts on this? I'd like to have a basic method for interfacing the Nic Collins/Lunetta circuits that I can use for each one I build.
mrmrshoes
PostPosted: Sat May 12, 2012 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers man, That case should do nicley. watch out for the case's depth when mounting circuit boards.
Thats a good thread. RichardC64 points out the dangers of interfacing dual supply signals with CMOS.
The danger is in going the other way: plugging +/- signals from a modular into single-supply cmos.
Thats why i recommended adding didoes to CMOS inputs to protect against negative Voltages. (I should take my own advice, I overlooked this when building my CMOS Machine Embarassed )
A safer way to do this is with Comparators (Analogue 2 Digital). I found this thread last night which might be of use to you.
http://electro-music.com/forum/topic-41933.html
Build a few to a panel
I need to experiment with this stuff myself but i'm still building my CMOS machine and i've not finished any modular units yet.
let me know how you get on.
mrmrshoes
PostPosted: Sat May 12, 2012 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
elmegil Great thread and arduino build by the way.
I was thinking of a different post, but yours is Really helpful. Thanks alot.
I need to study your design coz i just used midi Note messages to turn On/Off digital pins as make shift triggers and gates. I was using the MIDI Lib aswell, very useful but the documentaion is pretty bad. I had a couple of very frustrating days trying to do basic stuff. I haven't used it in a while so i'll be back to square one when i start working with the arduino again. Rolling Eyes
PostPosted: Sat May 12, 2012 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Very Happy
Dogue
PostPosted: Sun May 13, 2012 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting that link. It seems that's basically what Ken Stone does in his CGS CMOS designs. For instance in this schematic:
http://www.cgs.synth.net/modules/cgs39_quad_gate.html
So, buffering the inputs and outputs like that seems to be a good way of interfacing Lunettas with the analog modular.
mps board
