cebec
G2 patch files: 31
Posted: Wed Mar 02, 2005 11:12 am Post subject:
Strange Attractors: Creating Patterns in Chaos |
Don't know if anyone has seen this.
The book's out of print but has now been made available on the author's site.
http://sprott.physics.wisc.edu/sa.htm |
Audio files: 278
Posted: Wed Mar 02, 2005 11:42 am Post subject:
Thanks for posting that link, iinteresting book !!
(not sure though if it should be in the composition forum)
Jan. |
cebec
G2 patch files: 31
Posted: Wed Mar 02, 2005 11:50 am Post subject:
yeah, i wasn't sure where to put it. feel free to move it wherever you think it fits best. |
Audio files: 278
Posted: Sat Mar 05, 2005 1:34 pm Post subject:
From the book mentioned above :
Quote: | With actual music, it turns out that there are many more notes of short duration than of long duration. There are roughly twice as many half notes as whole notes, and twice as many quarter notes as half notes, and so forth. This remarkable result seems to hold for all types of music from different composers and cultures. It is evidence of hidden determinism in music. |
Whether this is actually true or not I don't know, but it seems to be interesting to experiment with.
Probably some composers already explored the use of this and other statistical properties of music in composition.
So I wonder ... does anyone have any pointers for me on this subject (before I end up with just another wheel) ?
Jan. |
Joined: Jan 31, 2003 Posts: 18197 Location: Durham, NC
Audio files: 212
Posted: Sat Mar 05, 2005 4:57 pm Post subject:
I have hear people use the term fractal to describe music, but this is really the first example of selfsimalarity I've seen. _________________ --Howard
my music and other stuff |
nescivi
Posted: Wed Mar 23, 2005 6:31 am Post subject:
The master of using statistics in music was Xenakis.
He has written some books on it, and there is an often quoted Computer Music Journal article about his work (though I don't know the title just now).
But that would be a good starter to find out.
Another thing a lot of people seem to be hooked on is Markov models and hidden Markov models.
Those are basically based upon counting how often a certain note appears, how often one note appears after another, how often three notes in a row, etc. You can go as far as you can and apply it on different levels as well (notes, phrases, etc.). |
Posted: Wed Mar 23, 2005 6:56 am Post subject:
mosc wrote: | I have hear people use the term fractal to describe music, but this is really the first example of selfsimalarity I've seen. |
Interesting that you should bring that up. Selfsimilarity in music has been on my mind for a while now, partially triggered by Road´s writing on scale in his "MIcrosound". Many of the techniques used to generate sounds can also be used to generate notes with some simple modifications. I´m not realy done with that thought yet, but thought it would be interesting to point out.
One thing this could possibly lead to is a conceptual modular system with only a few modules yet modules that can be used on many scales. Luckily mr. Smackos is away and so I can safely mention the Dual Universal Slope Generator as the possible source of our salvation in this field.
Another interesting (but completely different) take on this can be found on this site. That technique too could be argued to lead to selfsimilarness too. It might also be of interest to Nescivi who -like me- has developed a interest in a yet to be constructed grey area between baroque music and algorithems.
The overall thing these matters have in common does apear to be recursion, much more then -say- chaos.
Jan, for what it´s worth; I strongly feel this stuff belongs squarely in the middle of the composition forum. Reinventing wheels is a much better plan then most people think. The grand majority of people who use that expression simply do not realise the relative square-ness of the average wheel.
;¬) _________________ Kassen |
nescivi
Posted: Wed Mar 23, 2005 7:00 am Post subject:
for those who use SuperCollider... Julian Rohruber has made some interesting possibilities for recursive phrasing, which allows a very simple way of creating fractal music... |
Audio files: 212
Posted: Wed Mar 23, 2005 8:38 am Post subject:
Johnson's Self Replicating Loops article is very interesting, but without sound examples, I have a hard time following it after the introductory parts.
I have not used SuperCollider, but I have used Tim Thompson's Keykit program, http://nosuch.com/keykit/ , which is an algorhythmic composer's delight. (Tim is a member here, TJT, and is giving a talk at electro-music 2005.) In Keykit, I have played around with Markov chains but I've never liked the results musically.
Of course, random processes have been explored very deeply because they are so easy to create. Chaotic processes are more interesting because at times they are very periodic in nature and at times very random. The transisions between these states is interesting, like the transision between laminar and turbulent flow in fluid dynamics. _________________ --Howard
Posted: Wed Mar 23, 2005 9:06 am Post subject:
The second half of that article doesn´t realy "sound like" anything, it´s a little trick to get around the set-theory stuff in a way that makes the material easier to aproach from a compositional point of view instead of a mathematical one. _________________ Kassen |
vostek
Posted: Wed Mar 23, 2005 2:44 pm Post subject:
You guys know about fractal flames? They are based on the strange attractor principle. http://www.flam3.com/
http://www.electricsheep.org
http://www.apophysis.org/
It seems that this concept has been more successfully advanced in the field of visuals than in sound. I hope thats not the case for too much longer.I can imagine in my head the kinds of sounds that can be created with these algorithms, but of course i have no idea how to manifest the idea. |
Audio files: 212
Posted: Wed Mar 23, 2005 2:59 pm Post subject:
Those fractal flame images are beautiful. Please check the last link, it appears not to work.
EDIT-I fixed it for you based on EGWs post below. _________________ --Howard
my music and other stuff Last edited by mosc on Wed Mar 23, 2005 7:33 pm; edited 1 time in total |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Wed Mar 23, 2005 3:51 pm Post subject:
vostek wrote: | http://www.apophysis.org |
Wow, thanks. That is exactly the software I have been looking for.
(corrected the typo) |
bachus
Joined: Feb 29, 2004 Posts: 2922 Location: Up in that tree over there.
Posted: Thu Mar 24, 2005 6:42 pm Post subject:
Almost relevant to this thread is a simpleminded little algorithmic image generator I wrote that relies only on the sine and ellipse functions and bilateral symmetry in the creation of its forms. Bilateral symmetry is probably the most trivial kind of self similarity and is all that ties this program to this thread. The program runs under Win2000 and XP but would probably also run under NT. It needs a fast machine if it is not to be too boring. The signal to noise ratio is none too good. Only about one in a hundred images is interesting. Rather more rarely it produces something of startling interest and quality. On the other hand, if one's head is in the right place, it can be entertaining to watch it do its thing.
There is no manual, but under the menu option, Help, try "Tips and Commentary."
This program was written as an experiment in various methods of real-time interrupt of continuous background processes. The program's occasional sluggish or erratic response to its controls is the fruit of learning which methods don't work. _________________ The question is not whether they can talk or reason, but whether they can suffer. -- Jeremy Bentham |
Audio files: 212
Posted: Thu Mar 24, 2005 7:16 pm Post subject:
Thanks, Bachus. I enjoy this program. _________________ --Howard
Audio files: 278
Posted: Thu Mar 24, 2005 7:27 pm Post subject:
nescivi wrote: | The master of using statistics in music was Xenakis.
I'll have a look at Xenakis, that name seems to be written all over the place indeed and I didn't really go into that sofar.
I know ... this sort of defines the problem ... well it halped me see it in a different way.
Searching the internet reveals a lot of links going into techniques / algoritms of how to apply statistics in creating music. ButI was hoping to find some statistic "truth" about music, to use that to parametrize my own algorithms.
This hope though I now think, was an expression of laziness ... I should find my own truth in this. After all analyzing Bach in a statistical way & throwing the numbers into a model seems to yield Bach ... and that's not really what I want.
Took me a while to realize, but it was your mail that triggered the process. Thanks.
Jan. |
Posted: Thu Mar 24, 2005 11:10 pm Post subject:
Has anyone used artwonk? http://algoart.com/artwonk.htm
I've heard much hype about it lately (especially after it got an EM Magazine Product of the Year Award). It can generate images as well as MIDI, but I don't know how different it is to something like MAX/MSP, Keykit, or Pd. However, I suppose some of it's examples might be "transposed" to something more familiar to many here...like the G2.
I like their style too
Quote: | Competing Programs
There are few programs that provide the compositional power of ArtWonk. We know of only two. We feel ArtWonk is far easier to use than either of them, and is arguably more powerful. But you decide. Both have web sites and both provide download trials. We are so convinced you will conclude ArtWonk is the superior program, we'll give you direct links to our competetors. Here they are:
Cycling 74 Max/MSP for Windows
Tonality Systems Symbolic Composer For Windows
Audio files: 212
Posted: Fri Mar 25, 2005 7:24 am Post subject:
I reviewed ArtWonk when it first came out. http://electro-music.com/forum/topic-784.html
I have used Keykit extensively in the past, but I've never gotten into using MAX/MSP.
John Dunn, the developer of ArtWonk has been working on this kind of program for years. He supplies good support. ArtWonk is, MIDI only. I found working with it frustrating because of timing issues with clocks, but I'm sure experts can work it out with tips and tricks. It's modular patching is not with cords, but with pulldowns and names. I prefer cord like the G2 has. Still, you can do some great things with ArtWonk and it's worth a look.
Keykit is a programming language intended for MIDI output. Since it a procedural language, you can do virtually anything. It has a graphical interface as well, so you can actually program up you own widgets and tools if you wish. I like Keykit's approach better, but I'm a programmer.
MAX/MSP is more extensive than either since it can process audio as well as MIDI and images. I find reading MAX/MSP programs on the screen a bit difficult, but so is ArtWonk.
Each has their own charm. For me, to do MIDI generation and realtime processing, KeyKit is my program of choice. But my first choice is the G2 with it's MIDI modules for realtime stuff like custom arpeggiators and MIDI stream transformers. . _________________ --Howard
Posted: Fri Mar 25, 2005 11:34 am Post subject:
I had a problem with Artwonk´s smaller brother, I forget the name, it was the generation before wonk. I tried the demo and patched up what I thought should be fairly simple (admittedly it did involve easily over a hundered modules) and nearly brought the whole thing down. It was plagued by timing issues and realy, realy, bad clock jitter. in the end I had to quantise the whole thing down externally. It also suffered from "bit rot" in that saved files would randomly lose one or two connections and that every now and then modules would move around, that´s realy anoying if you are dealing with three figures of repetitive kinds of connection. Still, 2GHz of computer power should easily be able to deal with some midi without everything going to timing hell.
I prefer either cables or pure code, the problem with graphical interfaces is that it´s very hard to force a proper execution order for feedback loops. At least in the G2 it´s documented how this works... _________________ Kassen |
