tempco power rating
Page 1 of 1 [4 Posts]
wicked1
PostPosted: Mon May 07, 2012 9:35 am    Post subject: tempco power rating Reply with quote  Mark this post and the followings unread
How big do tempco's need to be? I've got several and just noticed they are 1/16 watt!
I ordered them years ago, as people on the SDIY mailing list suggested them. The person who made the post said to order some part number, 1/6 watt.
So, I ordered that. It looks like 1/6 is not a common size and the bag says "1/16 watt". (Im thinking the 1/6 the guy on the mailing list specified could have been a typo, and 1/16 is exactly what I want)
Will those work? I found some other posts where people were talking about using 1/10 watt SMD tempco's, so maybe 1/16 isn't too far off.
I'd obviously epoxy them to the chip they're adjusting.. I'd imagine being so small it wouldn't take much to fluctuate.
My concern w/ them being so small is self heating, or something.
Thanks for any advice.
andrewF
PostPosted: Mon May 07, 2012 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think in a typical VCO, where approx 18mV/oct is expected at the base of the transistor pair (so say it sees a max of 180mV), a 1k tempco won't have to deal with more than 0.05mW (a lot less).
1/16W rating should be fine.
frijitz
Audio files: 54
PostPosted: Mon May 07, 2012 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Andrew --
I believe the question is whether self-heating affects the resistance enough to give an incorrect reading, not whether it's going to burn out.
Way back when, Bernie went through the thermal analysis, but I don't remember the details.
When I was characterizing the Panasonic SMT tempcos I saw clear evidence of self-heating. But others have told me they don't see any problem. For me, this is unresolved.
Ian
wicked1
PostPosted: Wed May 09, 2012 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks.. Like Ian said, i'm sure they won't overheat in the sense of a standard resistor failing, but even a little warming would cause the compensation to drift...
Maybe I'll buy a few larger from one of the usual synth vendors, and save these tiny ones for a less critical project. (Im building 3 new vco's and I want them all to be stable and work well together)
Niio2
