What if post-sampled aliasing could be removed?
Page 1 of 1 [3 Posts]
audiodef
Audio files: 27
PostPosted: Mon May 07, 2012 6:56 am    Post subject: What if post-sampled aliasing could be removed? Reply with quote  Mark this post and the followings unread
It has been said that aliasing cannot be removed from a signal. Given that aliasing does not occur in a well-made sampling system, what would be the practical application of removing aliasing if it could be done?
Audiodef
Synthetronica
Gentoo Studio
Audio files: 217
G2 patch files: 93
PostPosted: Mon May 07, 2012 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
It would make it easier to implement a classical subtractive synth structure with sawtooths in ChucK, for one. Smile
The question is how expensive the post-sampled aliasing removal would be. If it were cheaper to just use pulse trains or (in the case of increasing the rate of a sample) filter out high frequencies before doing the up-sampling, then it wouldn't be an interesting thing to use.
How come? Do you have a magical algorithm up your sleeve? Wink
/Stefan
audiodef
Audio files: 27
PostPosted: Mon May 07, 2012 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, I was just reading an updated edition of one of my audio tech books. Naturally, when I came across a statement that X could not be done, I had to ask, well, what if it could be?
I also thought that even if it would be useless as a practical tool, it would be a nice creative one.
Audiodef
Synthetronica
Gentoo Studio
emSynth
