Problems with this Arp!
Page 1 of 1 [3 Posts]
Carl Mikael Björk
G2 patch files: 5
PostPosted: Sun Mar 20, 2005 3:21 pm    Post subject: Problems with this Arp! Reply with quote  Mark this post and the followings unread
I'm trying to build an arp that takes the first note in a chord (preferably the lowest one) and passes this on to a Seq for pitch/gate processing, the second note to the second arp, the third... and so on!
Problem no 1: I'd like only the first Seq to sound as long as I'm holding only one note. Only Seq1 and 2 if I'm holding two keys. And so on...
Problem no 2: It seems that the Status-Voice no. rather adds to the Mux than keep track of simultaneous keys pressed. Maybe I don't get how this works...
Could someone please, shed some light over this...?
Regards,
Mikael
Peggy-Pegiator!.prf2
Some sort of arp controlling three of my 8bit synths (could be any synths, I guess)...
 Filename:  Peggy-Pegiator!.prf2
 Filesize:  8.18 KB
 Downloaded:  1357 Time(s)
Electronic Music Tutorials Designed for Learning
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Mar 25, 2005 2:18 am    Post subject: Re: Problems with this Arp! Reply with quote  Mark this post and the followings unread
The voice number from the status module represents the voice number allocated by the very mysterious Clavia algorithm, if they used the 'Reset' mode from the old OB 4 voice then it would do what you expect Sad .
Putting midi send modules in a polyphonic VA is also problematic, simpler to use a mono slot or put them in the FX area.
You might get a two way version going using a couple of MonoKey modules, one set to low note, the other to high. This is how ARP and the Cat SRM got their duophonic mode.
Have posted a starter that shows what I mean.
dualKbdSyncSeq.prf2
just for illustration
 Filename:  dualKbdSyncSeq.prf2
 Filesize:  4.52 KB
 Downloaded:  1635 Time(s)
Carl Mikael Björk
G2 patch files: 5
PostPosted: Fri Mar 25, 2005 3:27 pm    Post subject: Re: Problems with this Arp! Reply with quote  Mark this post and the followings unread
Thank you, Sir!
I'll keep on experimenting with your advice in mind.
/Mikael
