Sourcing trimpots
Page 1 of 1 [9 Posts]
drakfluga
PostPosted: Wed May 16, 2012 4:15 pm    Post subject: Sourcing trimpots Reply with quote  Mark this post and the followings unread
Hey guys,
Where did you find your trimpots? I want to build a couple of LFO:s (one of each type) and they require a few trimmers. I've been unable to find any 10 turn 47K trimmers whatsoever, and most other ones I find have the wrong pinout. I expect it'd be fine to just bend the leads a bit and fit them anyway, but I'd like to come at least as close as possible.
Also, the trimmers I find seem quite expensive, at around €2-3 per.
The closest ones I could find to the LFO specs are these:
http://se.farnell.com/jsp/search/productdetail.jsp?sku=1141448
http://se.farnell.com/jsp/search/productdetail.jsp?sku=1141450
They are 15 turn, which I suppose is fine, and 50k instead of 47k. Will these do? Or am I looking in the wrong place?
Cheers!
marfoski
PostPosted: Wed May 16, 2012 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I recommend you this vendor:
http://www.taydaelectronics.com/potentiometer-variable-resistors/cermet-potentiometers/3296w.html
They are cheap and deliver very fast, too. Hope this helps.
drakfluga
PostPosted: Thu May 17, 2012 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one! Is it acceptable to replace 47k trims with 50k ones then? It should just increase the available adjustment range slightly, right?
marfoski
PostPosted: Thu May 17, 2012 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I am going to build myself two LFOs with those 50k trimmers. I think they will work fine, given that they have 25 turns of resolution and the difference is slight. But the last word belongs to Yves, of course.
iopop3
PostPosted: Thu May 17, 2012 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Since you're a fellow Swede I have to recommend electrokit. The 3266Y / 3296W pinout is what you need, i.e. three pins in row. But I have made successful orders from tayda and musikding.de as well.
Its all OK to use a 47k instead of 50k. Most of these trimmers have a tolerance of +/-10% or worser.
drakfluga
PostPosted: Thu May 17, 2012 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for info + link! One more webshop to look through. Trying to find one place to source as much as possible from which is cheap and well stocked, but so far I've had bad luck finding any one site who carries more than half of the components I need.
What sort of shipping costs are we talking about from Tayda btw? And can I expect any trouble from Swedish customs, i.e. tariffs or taxes? I'm guessing my order won't be more than a few hundred grams in weight; it's mostly small components like trannies, trimmers, caps and a few IC:s.
regularjackson
PostPosted: Thu May 17, 2012 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tayda's shipping is very cheap, it's usually only a few dollars to get a fair bit of stuff shipped to Canada.
iopop3
PostPosted: Thu May 17, 2012 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
drakfluga, the shipping costs are neglectable. As long as you're under 300SEK in value you're safe from tax and vat.
Good luck in finding a "shop-all-at-once" place, I usually shop from mouser, musikding, electrokit, tayda and a few others depending on mood/need. If you want to stock up on a bread and butter components like resistors, capacitors etc make sure to check out the surplus sales from bde.se .
marfoski
PostPosted: Fri May 18, 2012 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
... and there's always the old dear Futurlec that has the best ratio price/assortment. The only drawback it's that you have to be a zen monk to bear a delivery time of up to two months!
Niio1
