Joined: May 18, 2010 Posts: 308 Location: Oak Park, IL
Posted: Wed May 16, 2012 6:59 am Post subject:
Here's a video of my lunetta using a couple of ics. Believe it or not, I did not use my pitch tracker module at the end of the chain ! I'm just thinking out loud in my videos half the time; trying to envision a small battery operated unit that I can carry with me more easily than the great whale sitting in my Mancave.
Anyway, hope the video interests someone on some level to keep plugging forward.
Posted: Wed May 16, 2012 3:03 pm Post subject:
Kaputtpanzer, thats great At first I thought "you don't need to connect/disconnect the power pin of a 4093 to turn the oscillators on and off, just use the unused gate inputs!" but now I see it's doing much more! The capacitors add a power reserve which slowly discharges through the device, giving you that "beeewww" sound Very nice indeed.
Oh, and also, Draal, if you want some possibly inspiring material for your portable lunettas, give me a shout I've made something like that. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
I've been behind in checking up on this topic. Some really fantastic looking and sounding stuff. Lot's of creativity here. Congrats to all who have posted. Keep 'em comin' _________________ --Howard
Did you have any trouble with the banana jacks? The cheap ones I used would become loose so I ended up using 2 nuts on each then adding some thread locker to keep them secure.
Posted: Mon Jun 11, 2012 9:57 am Post subject:
sndbyte wrote:
Very nice looking machine!
I had that problem too, but I got some of these: http://www.rapidonline.com/Cables-Connectors/4mm-Test-Socket-Solder-Termination-Red-17-2893
Bloody brilliant quality! Machined socket, metal screw thread, they are the good stuff! I'm never buying any banana sockets without a metal screw thread again. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Joined: Mar 29, 2012 Posts: 47 Location: Malvern, Ohio
Posted: Mon Jun 11, 2012 12:11 pm Post subject:
Thanks guys, no trouble with the banana jacks yet. They do have metal screw threads and I think I got them really tight. Thread locker is a great idea though.
Posted: Mon Jun 18, 2012 1:09 pm Post subject:
That thing sounds amazing O_O how did you acheive those gritty, sort-of kick drum sounds? _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Posted: Mon Jun 18, 2012 1:39 pm Post subject:
Thanks for looking
I had a root canal today so I'm a bit loosy goosy in the thinking dept. but I'll give some estimation as to the sounds. I think the secret weapon is the 4046 as Pitch Tracker , but I'll explain this setup. The patch:
2 oscillators are the Data and Clock inputs of the 4094 shift register. I use a bit of trial and error in selecting 3 of the 4094's outs to use as controllers for the AB and C inputs of the 4512 data selector. As we've discussed briefly before in another post, any 8 channel or dual 4 channel multiplexor could work as well.
I use a 3rd oscillator to clock the 4040; 8 outs from there are connected to the Data Inputs of the 4512. A fairly fast clocking will get better octave ranges.
The output of the 4512 connects to my pitch tracker and then out to my passive mixer.
As to the 4046: I have switches to choose the caps at 2 points in the circuit (I need to post that pitch tracker scheme here; sloppily done or not ). In the clip I don't switch anything but the caps on my oscillators from fast to slow ones. At fast speeds, I can get pretty wild sheets of sound and at slower speeds, I can get more melodious.
So to answer your drum sounds question: the beat is created by my patching of the 4512 and the drum sounds (crude as they may be) come from the pitch tracker's attempts at tracking these beats. I have used this tracker for laser sounds but there is a wealth of more subtle settings to experiment with.
Heck, I'm waiting for my shipment of more 4046's this week _________________ Zontar Prevails!
Posted: Mon Jun 18, 2012 1:58 pm Post subject:
Thanks for the good explanation I think the 4046 pitch tracker is the key!
This device is so good it deserves it's own thread! Did you start one already?
I look forwards to seeing the results I bought 3 a while ago with plans to make ye olde pitche trackere and a frequency multiplier, but I have college work to do now _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
I thought I had already posted this here but I finally finished rehousing my lunetta in a more practical form. A big portion of what you see is the same board I started with in the absolute beginners thread.
Believe it or not, but this is actually the packaging for some high end watch someone gave me:
Fitting the boards:
Added a speaker and power supply, it also runs off a 9v battery so you can use it anywhere:
And here is the (so far) finished machine:
The dimensions of the boards is 16x18cm, and the closed unit is 20x20x15cm.
I'll try to do a more indepth video soon. _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson movies noise
Posted: Thu Jul 12, 2012 5:43 pm Post subject:
Here's a quick vid of my newest lunetta; I call him Pipboy and he provides a few extra ics for patching. 4078 8 input NOR gate, 4072 4 input OR gate,
4031 brought out to the panel (not as tap looper), two sets of dividers (4040 and 4020), and a 4029 up/down counter.
The 4029 has a 4017's outs patched into its Jam inputs.
Here's my lunetta collection slowly growing:
Filesize:
283.74 KB
Viewed:
208 Time(s)
Posted: Fri Jul 13, 2012 1:39 am Post subject:
my baby brother likes the sounds it makes _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
