Eurorack SN VOICE
Page 1 of 1 [6 Posts]
theglyph
PostPosted: Sun May 20, 2012 8:42 am    Post subject: Eurorack SN VOICE Reply with quote  Mark this post and the followings unread
Just finished this up a few days ago and it works wonderfully! Very Happy
LFLab
PostPosted: Mon May 21, 2012 2:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice!
I have two of these boards on the big stack. Can you share the FPD/PDF file?
Can't wait to try these out, should be a pretty powerful module.
Your layout seems to have the jacks a bit more to the outside, as opposed to Matthias' (fonik) which has the functionality more in columns and jacks in between the knobs.
Naturebot
PostPosted: Fri May 25, 2012 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I would love the files for this as well if you don't mind. Beautiful layout!
theglyph
PostPosted: Tue May 29, 2012 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I've attached the FPD files (Sorry for the delay).
Note:
The ENV/LFO/50%/20% setup is a combination of a C&K 7211 ON-ON-ON switch and a SPDT ON-ON switch with the center of the C&K connected to the SPDT.
The ENV Lock switch is the unlabled switch in the upper right side of the panel. It's also a C&K and it's Right/Lock, Center ENV and Left/Short ENV (the mod).
The ENV section has the Response mod and associated pot found here!
The panel has four countersunk M3 holes allowing for parallel mounting of the PCB.
SNVoice.fpd
SN VOICE FPD file
 Filename:  SNVoice.fpd
 Filesize:  1.91 KB
 Downloaded:  76 Time(s)
Audio files: 22
PostPosted: Tue May 29, 2012 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
LOVE IT ------ Very nice ! Neatly and logically laid out. Been slowly converting over to Euro myself but prefer to use the 1/4" style jacks. I have conversion cables to go between by PAIA and Blacet to my Euro and custom stuff.
Thanks for posting the FPD file Very Happy
Bill
Audio files: 22
PostPosted: Thu Jun 07, 2012 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
May I make one suggestion. If the panel is replicated, change the following: In the VCO section, change the spelling from "COURSE", which suggests a path or route, to "COARSE", which suggest a crude adjustment.
I have made this very mistake myself man !!! Laughing
Bill Very Happy
JuneSolstice2013
