32-stage massive phaser
Page 1 of 1 [5 Posts]
Rob
G2 patch files: 109
PostPosted: Fri Mar 18, 2005 3:23 pm    Post subject: 32-stage massive phaser Reply with quote  Mark this post and the followings unread
With reference to the previous posting [editor's note: http://electro-music.com/forum/topic-5684.html --mosc] about the warmth trick and the allpass filters constructed with mixers it had to happen, a 32-stage phaser. Each allpass stage is made with a 6dB LP filter and two simple mixer modules. 32- stages fit just in one dsp, so with use of the bus modules one could probably go to a max of 128 stages. Of course there is a miriad of modulation possibilities with such a selfconstructed phaser, as each stage could have its own modulation.
The patch uses just tiny thin pulses to excite the two phaser channels. Watch out for the low end, its wicked.
MassivePhaser.pch2
A 32-stage stereo phaser (with an earthshaking low end).
 Filename:  MassivePhaser.pch2
 Filesize:  8.94 KB
 Downloaded:  1412 Time(s)
ik
G2 patch files: 25
PostPosted: Sat Mar 19, 2005 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow. This is massive! Cool
Great patch.
Rob and all ...,
Clavia did not publicized (or I just missed) the possibility of doing this "low" (or lower) level dsp approaches to construct filters, oscs, ...
This brings an enormous level of flexibility to the G2 ...
Any hope to see a "Math" module in the future something like the
'Logic/Gate ... AND/NAND/OR/NOR...' module, but with MATH operations like +/-/*/div/a^x/log x/mod x/abs x/round x ....???. (I know some of them already 'there' in the form of mixers/shapers ...).
Is it possible at all? I mean ... How 'deeply' the G2 hardwired ... ?
Thanks for your work and input.
ik.
Audio files: 138
PostPosted: Sat Mar 19, 2005 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
"Massive" is right. This is something else. Thanks...
grimley
G2 patch files: 9
PostPosted: Sat Mar 26, 2005 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
This sounds great but I'm having a tough time trying to figure out how to use it as a building block!!! Where are the inputs to the phaser?
Thanks,
grimley
Rob
G2 patch files: 109
PostPosted: Sat Mar 26, 2005 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
grimley
Yes, you're right about this not really qualifying as a 'building block', I should better have posted it at the experimental patches forum.
The input is basically the output of the little HP filter that is right after the osc at the topleft corner of the patch. All the blue wires that go from the lfo modules at the top row are the modulation signals. So it is best to put it in the FX area of a patch and simply replace the osc and hp filter at the topleft corner by a FX-In module. Then you should be set.
/Rob
