Strange problem: My Andromeda has internal latency
Page 1 of 1 [6 Posts]
CommandorX
PostPosted: Sat Feb 25, 2012 12:07 pm    Post subject:  Strange problem: My Andromeda has internal latency Reply with quote  Mark this post and the followings unread
Hello.
Today I started up my synth for the first time in a long while. After the regular auto-tuning, I discovered that every time I hit a key, the sound would appear several miliseconds (probably 20 or 30) late.
I tried soft reset, hard reset, with and without card, turning all pots/pressing all buttons, using MIDI as an alternative trigger - and several reboots.
I also found that the pots themselves had a delay, like when rapidly adjusting the main volume - the same miliseconds were in between.
Does anybody here have experience with this kind of A6 behaviour?
Any help is appreciated. I really hope to
solve this as soon as possible.
Thanks,
CommandorX
andyval8088
PostPosted: Sat Feb 25, 2012 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
If the problem is happening on all the controls and after a hard reset I would probably try re-seating the ribbon cables inside. Not sure if anyone else has a guess?
do the numbers/values on the screen seem to represent the latency when you turn a knob? also, what outputs are you using?
The Real MC
PostPosted: Mon Feb 27, 2012 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
You don't have a MIDI loop do you? Does it behave better if you pull the MIDI cables?
CommandorX
PostPosted: Thu Mar 01, 2012 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for replying!
I tried both with and without a MIDI hook-up. No difference.
How would I proceed to reseat the ribbon cables? I have never opened a synth before.
CommandorX
PostPosted: Thu Mar 08, 2012 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi again.
Does anybody here have experience with reseating the ribbon cables?
sempervirent
PostPosted: Fri May 25, 2012 8:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
You probably figured it out by now, but "reseating" is just a fancy term for unplugging the cable and plugging it back in.
