 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc » TC-11
TC-11 video capture
robert@lauriston.com
PostPosted: Mon May 28, 2012 11:48 am    Post subject: TC-11 video capture Reply with quote  Mark this post and the followings unread
Sharing this since it took me a while to figure out how to do a video capture from TC-11 including audio.
1. Jailbreak your iPad. I used Absinthe.
2. Buy Display Recorder through Cydia.
3. Start Display Recorder recording.
4. Switch to TC-11 and play. Note that the video file takes about 1GB per minute.
5. When done, switch back to Display Recorder and stop it.
6. Switch back to TC-11 and do Record > AudioCopy > Copy Audio. You don't need to paste it into an application.
7. Connect the iPad to PC or Mac, go to iTunes, and save the TC-11 audio file to disk.
8. Turn on Display Recorder's Web server and download the video file.
9. Use a video editor to combine and synchronize them the audio and video.
I presume you could do steps 7-9 with an iPad video editor.
I also tried patching my IO Dock's outputs to its inputs and using Display Recorder's "H.264 + Mic" format, but as soon as I switch to TC-11 the audio track goes silent. That does work with Animoog and Samplewiz.
http://youtu.be/7n1UcrmmkVU
JuneSolstice2013
