  Paulo Santos Synth-ing NºX
Step Seq FX mashup
Page 1 of 1 [12 Posts]
wheely
PostPosted: Wed May 30, 2012 3:10 pm    Post subject: Step Seq FX mashup Reply with quote  Mark this post and the followings unread
Has anyone made a patch that takes audio in, and using a step sequencer, it sends the audio signal off to different fx modules.. bit like dbglitch, effectrix, stutter edit etc.
cheers.
Roland Kuit
G2 patch files: 127
PostPosted: Wed May 30, 2012 11:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
In my SoundLab II you can find a few. Here's one. Just skip the VA part and get your audio-in in the FX part.
http://electro-music.com/forum/post-359532.html#359532
You can add audio to fx modules and put them into a sequencer controlled multiplexer.
wheely
PostPosted: Thu May 31, 2012 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Roland, ill take a look at that tonight.
wheely
PostPosted: Sun Jun 03, 2012 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Roland, having a little difficulty with the patch. pretty new to this. I have audio goin into the patch, but not sure what u mean by seq multiplexor.
Roland Kuit
G2 patch files: 127
PostPosted: Sun Jun 03, 2012 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
See my last post here:
http://electro-music.com/forum/post-362558.html#362558
Mux module is a multiplexer.
wheely
PostPosted: Sun Jun 03, 2012 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
i see, so all the signals are summed or split from the mux?
how can i adapt this, so that instead of the sequencer putting out kick and snr to the oscs, the seq instead automates the fx modules, so like on say on number 5 it send to the feedback delay, and when it hits number 15 it send to reverb etc.
thanks.
Roland Kuit
G2 patch files: 127
PostPosted: Sun Jun 03, 2012 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Split, the Mux is a switch module. And there is a Mux with variable x-fade.
A fading switch.
Your question is not clear for me.
Do you mean, instead the drums in the VA part, get audio through it?
Just change the FX-in module by an Audio-in module. Delete the VA part.
wheely
PostPosted: Sun Jun 03, 2012 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
i mean, feeding audio into it like a drum loop, but the step seq triggers different fx as it moves along. its prob me not explaining very well, sorry. Smile
anigbrowl
G2 patch files: 5
PostPosted: Sun Jun 03, 2012 8:30 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Here are 2 patches that do what you like. FX switcher is switching a 1-8 multiplexer to send an input signal to one of 8 destinations. You can put more interesting effects in, I just took some delays from another patch and 4 random default FX. You could use a control sequencer instead of a pattern generator, of course. Or use 2 multiplexers and two pattern switchers or whatever...this is not an interesting-sounding patch yet Embarassed For a glitchy sound make the delay times much shorter
Random Clock delay is something I was already working on today, it randomly sw3itches between 4 clocked delays. The switches don't have a control input so we assign a MIDI controller to the 4-way switch unit and send a control value to 'this' slot, ie back into the same patch. (This is a very useful trick for automating anything in the NM that does not have a control input.) It's good to keep the feedback at zero and the delay units at 100% wet so the signal does not become a mess.
Note that you need to check which inputs are being used. I was adding effects to another patch sent via the internal bus signal when I made the delay patch. Also, you could do all this in reverse - feed the input signal to a variety of different effects and then use an 9-1 multiplexer to switch between them as Roland suggests (the crossfade facility on the 8-1 multiplexer ensures you won't get annoying clicks when switching around).
FX Switcher.pch2
 Filename:  FX Switcher.pch2
 Filesize:  1.86 KB
 Downloaded:  1017 Time(s)
Random Clock Delay AB.pch2
 Filename:  Random Clock Delay AB.pch2
 Filesize:  1.51 KB
 Downloaded:  1033 Time(s)
Roland Kuit
G2 patch files: 127
PostPosted: Mon Jun 04, 2012 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="anigbrowl"]Random Clock delay is something I was already working on today, it randomly sw3itches between 4 clocked delays. quote]
I have a much more economical way for Delay-time switching. But I'm in the train now. I will look it up for you.
wheely
PostPosted: Mon Jun 04, 2012 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
ah nice wan, i see how this works now, cool, ill have a mess around, cheers guys.
anigbrowl
G2 patch files: 5
PostPosted: Fri Jun 08, 2012 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this one is very wasteful of memory; as there's no feedback it would be much better to modulate the delay time; I just threw it together quickly for a patch that was already playing in a different slot. I will be interested to see yours, though!
