Circuit Bent Coleco Talking Teacher
Page 1 of 1 [3 Posts]
seaweedfactory
PostPosted: Sat Jun 02, 2012 9:44 am    Post subject: Circuit Bent Coleco Talking Teacher
Subject description: with schematics
Here's my take on bending the Coleco Talking Teacher toy. There are a few schematics floating around, but the bends on them don't quite work as advertised.
The two of the glitch loops use 25K potentiometers in such a way that the bend is deactivated when the potentiometer is rotated to maximum resistance. This means a switch is not necessary to activate the bend and that the bend is adjustable. Different sounds are produced by these bends a different resistances. At lower resistances the sound will subtly glitch between what it should be and a slightly off variation. At higher resistances, the sound is fully glitched and unrecognizable. The bend which does use a switch did not react to variable resistance in an interesting way.
To perform the pitch modification the onboard pitch adjustment trimpot must be removed. Because this part of the board is crowded, the easiest way to do so by wiggling the trimpot until it breaks free of the board. After this has been removed, a new 500K potentiometer can be soldered in it's place.
This is one of the most stable talking toys I have bent. The long and short loops are repeatable, so the glitches can be played like you would a drum machine or keyboard. The sound is also very clear.
Bent Coleco Talking Teacher diagram
 Filesize:  203.65 KB
 Viewed:  44 Time(s)
Blog: http://seaweedfactory.blogspot.com/
Youtube: http://www.youtube.com/user/SeaweedFactory
JingleJoe
PostPosted: Tue Jun 05, 2012 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
That was pretty cool Smile I assume that 500k pot was the clock speed control? You could maybe even add some kind of weird external clock from some logic gates.
As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
seaweedfactory
PostPosted: Tue Jun 05, 2012 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Joe!
The 500K potentiometer is the clock speed control. It has a fairly limited range at the high end. Shorting the two points results in a maximum for the speed. I think an external clock would be the only way to get past this limit.
Niio1
