treehugger
Posted: Tue Dec 21, 2010 5:02 pm Post subject:
Success at last Subject description: Moc OS X 10.6.5 and Nomad |
I have finally, after severla years now of trying, been able to get a stab le connection between Nomad and my two Nord Modulars. It's AWESOME to have them back online again. Here's how I got it to work
1) update to OSX 10.6.5
2) remove Mandolane, or any other installed java midi "helper" files, using the appropirate Uninstaller.
3) Do NOT use a multiport interface to connect to the PC IN/Out ports on the NORD. Use a simple single port USB interface (with the latest drivers of course) Mine is an M-Audio MididMan. The multiport interfaces (or at least mine) generates a parse error exception, even though communication has been established. I believe that this is due to an extra port identifier packet in the MIDI stream of a multiport device.
4) make sure your interface is correctly intalled, and your NORD PC In/Out is connected to the in and out port of this interface using the Audio/MIDI Setup utility.
5) Restart your Mac.
6) Launch Nomad and make brand new synth connection to the single port interface.
7) Dance in delight as patches get effortlessly passed back and forth! |
Joined: Apr 03, 2004 Posts: 19621 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Tue Dec 21, 2010 6:07 pm Post subject:
Great you have it working!
Good to see a success story too  _________________ Jan |
treehugger
Posted: Tue Dec 21, 2010 9:01 pm Post subject:
| Yup, I was just about to put htem up on ebay at a firesale price. I was pretty discouraged, but this made my day! |
Joined: May 16, 2005 Posts: 8905 Location: Birmingham, England, UK
Posted: Wed Dec 22, 2010 4:21 pm Post subject:
Hope you don't mind, but I've made this thread sticky, so that others having similar problems will find the solution to their Nomad on OSX problems quickly
Tom _________________ ACHTUNG!
Audio files: 116
G2 patch files: 317
Posted: Wed Dec 22, 2010 5:28 pm Post subject:
Thanks Tom, good idea. _________________ Jan |
nomay
Posted: Fri Feb 25, 2011 11:07 am Post subject:
ok- tried this with my generic single port interface and didn't work. Also with my midisport 2x2.
wondering if it really is the interface?
Anyone else have any luck with this?
Is the nomad editor worth the price of a new interface?
ANY help on this would be appreciated- I'd like to know how many snow leopard people are running nomad successfully! |
Moody33
Posted: Fri Feb 25, 2011 4:12 pm Post subject:
| I've a midisport 2x2 and it works with nomad on my macosx snow leopard 10.6.4 . I don't really use nomad though, I've just test it some month ago and it seems to works fine. |
nomay
Posted: Fri Feb 25, 2011 7:29 pm Post subject:
Moody! You are giving me hope.
Did you do anything special to get it to work?
What's your secret? |
Moody33
Posted: Fri Feb 25, 2011 7:55 pm Post subject:
| Nothing special as far I remember. I will take a look later. |
Posted: Mon Feb 28, 2011 1:36 pm Post subject:
Nomay, have you tried a different USB connecting cable? _________________ ACHTUNG!
nomay
Posted: Tue Mar 01, 2011 8:55 pm Post subject:
| yes- I've tried different midi cables, but it's always worth another shot. I was under the impression that no one was using Nomad on Snow Leopard. It seems that people are getting this to work, so I will go back and try to get this going. This forum is giving me hope! |
nomay
Posted: Wed Mar 02, 2011 8:06 pm Post subject:
more experimentation tonight. different midi cables. same thing.
Question: I'm running the clavia editor successfully. What needs to be changed to run Nomad?
When I click on the orange diamond (next to the wrench)- I get this error (maybe someone knows how to read this?):
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:633)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 11 more |
sYn
Posted: Thu Jun 07, 2012 4:22 am Post subject:
No more NM1 editor on OSX Lion and future?! Subject description: No more NM1 editor on OSX Lion and future?! |
Hi everybody,
i've been a nord modular G1/G2 user for long times and today after updating to Lion i realised that the Beta editor was not working anymore (PowerPC app not supported). I tried many times to run Nomad, but i always got this error message:
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1339062837059 [error=-1001]
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:682)
at java.awt.EventQueue.access$000(EventQueue.java:85)
at java.awt.EventQueue$1.run(EventQueue.java:643)
at java.awt.EventQueue$1.run(EventQueue.java:641)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:652)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1339062837059 [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmProtocol.heartbeatImpl(NmProtocol.java:5
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular$SchedulingProtocol.heartbeatImpl(NordModular.java:252)
at net.sf.nmedit.jnmprotocol2.AbstractNmProtocol.heartbeat(AbstractNmProtocol.java:154)
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:114)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:358)
... 17 more
I followed all the advices about nomad on this forum but it is still not working.
I start to believe that my interface is the problem, M-Audio Midiman UNO USB, but apparently everybody runs it on Midiman 2x2 successfully (really similar to mine, same drivers...).
Does anybody managed to get Nomad working on OSX Lion?
What is the most compatible USB MIDI interface to use?!
I love my modular, really don't wanna sell it.... HELP please!!!
Thanks |
Clandestine Monarchy
Posted: Tue Nov 13, 2012 4:47 pm Post subject:
No connection options visible |
Hi I'm running Mac OS X 10.8
When making a connection to my nm, I don't get to see any connection options at all. The screen where they should normally appear is just blank...
please help, I'd love to continue using my nm in mac |
Kultist
Posted: Mon Jan 21, 2013 9:30 am Post subject:
Made it work on OS X 10.8.2 |
For what it's worth now, here's how I managed to make Nomad work here on Mac OS Mountain Lion (10.8.2) using a Edirol US-1MX, with only the 2 java lib files supplied on the Nomad .DMG.
The only thing I can say is that getting a single-port MIDI device with non-internal driver was the key. I had been trying to connect Nomad to my Modular for some time now with a cheap MIDI-to-USB adaptor with an internal driver
(such as this one http://www.amazon.com/USB-MIDI-Cable-Converter-Keyboard/dp/B003KXEDVQ/ref=sr_1_6?s=electronics&ie=UTF8&qid=1358785541&sr=1-6&keywords=midi+to+usb+adapter)
The one I was using was creating a virtual MIDI out port for some reason, which seems to confuse Nomad. Make sure you are using a MIDI device that creates a single MIDI I/O pair.
Also, those who cannot see the MIDI I/O option in the Connection Settings pane of their Modular should make sure they DO NOT have mmj.jar in their /Library/Java/Extensions, as this is what makes the pane show up empty (from my experience). |
secretkillerofnames
Posted: Mon Mar 25, 2013 8:15 pm Post subject:
So yeah problems getting nomad to work on OSX 10.8.2 / OSX 10.6.8 and Bootcamp Win7. Same timeout error [-1001]
I just picked up a Roland UM1 Mk2 that has allowed me to use this with the Final Clavia Editors on Snow Leopard and in Win7 / Bootcamp without problems.
However none of the solutions working for other people have worked for me yet. |
