linear or log?
Page 1 of 1 [6 Posts]
regularjackson
PostPosted: Thu Jun 07, 2012 8:51 pm    Post subject: linear or log? Reply with quote  Mark this post and the followings unread
I'm a total noob when it comes to electronics. I get some things and I've managed to build some circuits from schematics on this sub-forum, but every time I come across a pot in the schematics, I don't know if I should be using log or linear pots. What exactly is the difference, and how do I figure out which I should be using? Any help is appreciated, thanks!
Mikmo
PostPosted: Thu Jun 07, 2012 11:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
This might help:
http://www.geofex.com/article_folders/potsecrets/potscret.htm
http://sound.westhost.com/pots.htm
Stay Cool
Mikael
http://www.mikmo.dk
Audio files: 254
PostPosted: Fri Jun 08, 2012 3:31 am    Post subject: did someone say pot ? Reply with quote  Mark this post and the followings unread
If you're using an existing schematic it's usually mentioned what you need. If there is no mention it's presumed to be a linear pot. There
are different notations, I grew up with A meaning linear and B meaning log, but apparently some manufacturers now use A (as in Audio)
for log and B for linear Confused . So that might be confusing. I just use 'lin' or 'log' in my schematics.
Since you posted this in the Lunetta forum, you will probably use pots mostly for oscillators. You can use linear pots for these but personally
I prefer reverse log (if you can find them). You can also use a normal log and wire it backwards but that will result in the frequency
decreasing when turning the pot Clockwise.
http://www.acidtrash.com/
Draal
PostPosted: Fri Jun 08, 2012 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I prefer audio pots for most stuff; the ear perceives the change more gradually with audio taper. That said, I use whatever is on hand, bro, these machines love whatever ya throw at em. Very Happy
Zontar Prevails!
JingleJoe
PostPosted: Fri Jun 08, 2012 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I was going to post a link to one of those two pages mikmo posted, because of this. I often find that when purchasing log pots I can't find anything that says whether it is commercial or true log, so I tend to stick to linear pots. However as mentioned above, human hearing is not linear so log pots/anti log sound linear to us.
As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
regularjackson
PostPosted: Fri Jun 08, 2012 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Great, thanks everybody!
Niio1
