problem patching between two modular devices
Page 1 of 1 [5 Posts]
marcelds
PostPosted: Fri Jun 08, 2012 10:27 am    Post subject: problem patching between two modular devices Reply with quote  Mark this post and the followings unread
just finishing building a small basic synth unit, stands alone and runs on 9v - it has a banana patch bay of outputs and inputs. when i tried to link another similar unit's outputs to its inputs, it didn't work. even trying to send an oscillator voice from the second unit through the main audio out of the first unit didn't work. is this because they're running from different power sources?
Audio files: 218
G2 patch files: 319
PostPosted: Fri Jun 08, 2012 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Separate supplies, yes, in a way ... you'll need a ground connection between the two devices for cross patching to work.
marcelds
PostPosted: Fri Jun 08, 2012 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, makes sense - a simple banana jack to each ground will do? are there any drawbacks to this?
Audio files: 218
G2 patch files: 319
PostPosted: Fri Jun 08, 2012 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
yes.
When all is properly made, nope.
marcelds
PostPosted: Sun Jun 10, 2012 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you!
