Analog Or Gate?
Page 1 of 1 [15 Posts]
corex
PostPosted: Wed Jun 27, 2012 10:23 am    Post subject: Analog Or Gate?
Subject description: How to pass the greater of two signals?
I have a problem where I would like to pass the greater of two signals, a kind of "analog or". It seems to me that this has come up before, but search fails me. Anybody have a schematic, or even a better keyword?
JingleJoe
PostPosted: Wed Jun 27, 2012 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Two diodes should do.
simply make a diode based OR gate, with a pull down resistor on the end, that will pass analogue voltages above the diode voltage.
corex
PostPosted: Wed Jun 27, 2012 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm looking for something a little more sophisticated; the diodes will have a voltage drop and won't pass bipolar signals.
JovianPyx
Audio files: 123
PostPosted: Wed Jun 27, 2012 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm... A comparator monitors the two voltages. The voltages are then passed through two transmission gates of a 4066 which is controlled by the comparator and the logically inverted output of the comparator. Of course, that puts limitations on the range of voltages it will pass. I.e., you can expect to pass a range of +15 to -15 through a transmission gate. The transmission gates outputs are connected together to form a single output. May need resistors on the xmission gate outs, not sure.
FPGA Synth Stuff
FatMan Mods
dsPIC Synth Stuff
I am formerly known as ScottG here
Time flies like a banana.
andrewF
PostPosted: Wed Jun 27, 2012 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is what you need...............maybe
http://electro-music.com/forum/topic-21851.html
brock
PostPosted: Wed Jun 27, 2012 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
There may be an error here. The limitation is you cannot pass +15V to -15V through a CD4066, but if you use a DG403 it should work okay.
If you are comparing audio or periodic inputs you probably want some kind of peak detectors or envelope followers on the input signals for the comparator control.
JovianPyx
Audio files: 123
PostPosted: Thu Jun 28, 2012 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Not sure if it's an "error", more of a memory lapse - I couldn't remember the part number you cited. However, I think that the technique would work, no?
FPGA Synth Stuff
FatMan Mods
dsPIC Synth Stuff
corex
PostPosted: Thu Jun 28, 2012 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys!
The comparator + switch combo sounds like a workable approach. I didn't know about DG403, but looking over the datasheet it does seem more appropriate than the 4066. (For onlookers: the 4066 switches analog signals up to +/-7.5V peak, whereas the DG403 will switch signals up to +/-15V ptp.)
I'll do some experiments along these lines.
brock
PostPosted: Thu Jun 28, 2012 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
The concept will work no problem. I think Aries may even have made a module like this in their analog switch which, if I recall correctly, could be controlled with an analog voltage. High probability of memory lapse on my part with that guess/memory though as that's going back a long time.
wmonk
Audio files: 12
PostPosted: Sun Jul 01, 2012 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is the YuSynth Min/Max that does this.
Easy to build and a module I love.
http://yusynth.net/Modular/EN/MINMAX/index.html
Weblog!
Kits for synthesiser modules in Europe
Audio files: 254
PostPosted: Mon Jul 02, 2012 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
hadn't noticed that one before, great I'll put it on the todo list. Cool
http://www.acidtrash.com/
corex
PostPosted: Mon Jul 02, 2012 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! It's nice to have a couple of options, and this looks like a completely different approach.
corex
PostPosted: Mon Jul 02, 2012 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
TL071/072/074 should be okay instead of LM324 in the YuSynth circuit, right?
JingleJoe
PostPosted: Mon Jul 02, 2012 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
That depends, how close to the rails do you need them to operate? I've had trouble with them TL07X's when operating at input voltages near the supply rails. They aren't designed for that, unlike the LM324 which can go all the way to the negative supply because it is designed for single supply operation. Input voltage ranges are the main concern here.
corex
PostPosted: Tue Jul 03, 2012 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
That makes sense, yeah. I looked over both datasheets and that was all that really stood out to me -- that the LM324 is meant for single-sided rail-to-rail operation. For my purposes, I think I don't care about rail-to-rail so that answers that.
