Inverse sustain possible?
Page 1 of 1 [8 Posts]
Astral
PostPosted: Thu Jun 28, 2012 2:51 pm    Post subject: Inverse sustain possible? Reply with quote  Mark this post and the followings unread
Anyone know if it's possible to inverse the sustain pedal globally? Nothing in the manual index references sustain, perhaps its under a different keyword.
CoolColJ
PostPosted: Fri Jun 29, 2012 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the A6 does it automaticly be sensing it when you first turn it on
Astral
PostPosted: Sat Jun 30, 2012 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, it sure does. many thx!!!
Although I didn't get the desired result. As a controller I wanted it stay normal, dont think that usage is possible.
Basically wanted to load up a string patch on the andy, and a piano patch in kontact. I wanted to let the piano patch sustain while the string patch only work when the keys are pressed.
Still good to know how to invert the sustain, thx again!
Mefistophelees
PostPosted: Sat Jun 30, 2012 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
What do you mean by "inverse the sustain pedal"?
http://soundcloud.com/Mefistophelees
Astral
PostPosted: Sat Jun 30, 2012 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
instead of notes sustaining when sustain pedal is pressed, they sustain when its not pressed.
CoolColJ
PostPosted: Sat Jun 30, 2012 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
use a midi filter like MidiOX with an internal port router to invert it
There are 2 good ones on WIndows - LoopBe and LoopMidi
Astral
PostPosted: Sun Jul 01, 2012 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ahh very cool, I'll give that a shot. thx!!
sunny pedaal
Audio files: 12
PostPosted: Tue Jul 03, 2012 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
maybe the trackinggenerator might help for this ?
