Inventor
Joined: Oct 13, 2007 Posts: 5947 Location: San Antonio, Tx, USA
Audio files: 256
Posted: Wed Jun 27, 2012 11:04 pm Post subject:
eChucK Reborn! Subject description: as a breadboard-based concept |
I've given some thought to the eChucK project and how to breathe some life back into it. I recall that when the project got mentioned on MatrixSynth there were a ton of web hits on it. People want an affordable synthesizer system.
Well, I was looking at some breadboards and jumper wires and I've never lost my fascination with the breadboard as a prototyping method. I make really neat breadboarded circuits that are easy to trace and debug - it's another art form really.
Well, thinking about eChucK and breadboards and eChucK and breadboards and --- well, you get the idea: how about using the breadboard as the basis for eChucK? The concept is as follows.
I'll design those eChucK modules as circuit boards that plug into breadboards vertically using single in-line connectors. I can have the boards made at SparkFun for low cost in low production volume so the problem of spending a few hundred bucks on each board type is gone. Then the breadboard will serve as the interconnection mechanism for the eChucK modules.
The result is a more densely packed breadboard that you can still wire custom circuits on, but you also have standard modules that you can combine as well. Capital idea, don't you think? I'll work on it tonight.
Les _________________ "Let's make noise for peace." - Kijjaz Last edited by Inventor on Fri Jun 29, 2012 7:04 pm; edited 1 time in total |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Fri Jun 29, 2012 4:53 pm Post subject:
Sounds very reasonable to me, Les. Be sure to include photos when you get something. _________________ --Howard
my music and other stuff |
Inventor
Audio files: 256
Inventor
Audio files: 256
Posted: Fri Jun 29, 2012 7:20 pm Post subject:
Alrighty then, here is the design for the first board. Well, the actual credit for the board's schematic core goes to another em'er in the Lunetta forum. I shall send him a free board as a thank-you. (note to self: do that!)
I'm really happy with the layout and the space savings, it requires about 25% of the breadboard space compared to building it yourself, plus it's really cool. It's like the isolinear chips that Data was swapping around at a furious Data-like pace as the supernova approached the Enterprise on that Star Trek episode. "This will require slightly more time than we have before the ship is destroyed, Captain!"... but they survive by some miracle anyway!
That's like eChucK - the vaporware that attracted all that attention almost died a death of lack of funds and direction but here a couple of years later it lives again! This time for real!
Les
| Sine Wave Thing Schematic - every 8 clocks you get a sine wave! |
 Download |
| Filename: |
SineWaveThingSCH.pdf |
16.74 KB |
| Downloaded: |
110 Time(s) |
| Sine Wave Thing PCB 8 pin SIP - tall boy! |
 Download |
| Filename: |
SineWaveThingPCB.pdf |
15.75 KB |
| Downloaded: |
80 Time(s) |
_________________ "Let's make noise for peace." - Kijjaz |
Inventor
Audio files: 256
Inventor
Audio files: 256
Posted: Sat Jun 30, 2012 3:01 am Post subject:
Still awake on a weekend caffeine buzz (a gallon of sweet tea - mmm), I have created the second board in the eChucK module series. It is a solar power board that works in a really nifty way.
The solar cell is a thin film flexible type so it wraps around a pencil - or in this case the end of a circuit board. That way the 4.5" long solar cell is halved in length and collects light on both sides. The header is two rows by five pins, so it plugs right into the power bus of the breadboard. Use one for a 3V supply or better yet use two for a center tapped 6V supply. Current rating is 25mA, plenty for CMOS circuits. Need more current? just parallel another Solar Power Module. Simple and easy!
The board can also be used as a light sensing element if desired. PDF with board layout and image of solar cell attached.
Les
| Flexible Solar Cell, wraps around a pencil |
11.48 KB |
| Viewed: |
1485 Time(s) |
| board layout for Solar Power eChucK module |
 Download |
| Filename: |
SolarPowerPCB.pdf |
42.1 KB |
| Downloaded: |
62 Time(s) |
Inventor
Audio files: 256
Posted: Sat Jun 30, 2012 4:11 am Post subject:
Here are the instructions for the Solar Power Module. Also shown below is an image of the Sparkfun clear plastic enclosure that would make a great companion to solar powered eChucK projects.
Les
| an excellent clear plastic enclosure from Sparkfun for eChucK projects |
46.08 KB |
| Viewed: |
1477 Time(s) |
| Instructions for the Solar Power Module |
 Download |
| Filename: |
SolarPowerInstructions.rtf |
1.66 KB |
| Downloaded: |
55 Time(s) |
Inventor
Audio files: 256
Inventor
Audio files: 256
Posted: Sat Jun 30, 2012 5:54 pm Post subject:
I had a lot of leg pain so I slept and walked to reduce it, could not work. It's gone now so I've just gotten back into things and I created a Stereo In and Stereo Out module. These have 1/8" jacks and work with line-level signals as well as the Stereo Out module drives headphones directly off of the board. Also there are internal signals tapped for monitoring and for using the voltage followers as buffers without using the 1/8" jack should that be needed.
I also reduced the number of pins on the Solar Power module from 2x5 to 2x3 so they can be located on the main breadboard field if so desired. Plus I figured out the spacing on the Sparkfun project box's mounting grid and set all the holes to line up with it properly.
Next I suppose we need an oscillator module of some sort, eh?
