CC TX on but onlysends mod wheel but none of the other knobs
Page 1 of 1 [3 Posts]
Astral
PostPosted: Sat Jun 30, 2012 4:25 pm    Post subject: CC TX on but onlysends mod wheel but none of the other knobs Reply with quote  Mark this post and the followings unread
I am trying to cc learn in kontact, but the only cc's that kontact recognizes is the pitch, and mod wheel. Is there a way to use something like the filter knob?
I have TX MODE set to "midi'
and CC TX set to "on"
Figured that would do it, but in my daw, I see it getting the midi but it comes in as "unhandled".
sunny pedaal
Audio files: 12
PostPosted: Tue Jul 03, 2012 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
it sends mostly msb-lsb instead of cc's.
advantage is far better parameter resolution.
disadvantage is only few daw's can do something other with it then simply record/playback.
for sending of cc's you're limited indeed to the wheels/ keyboard /ribbons
ps receiving cc's is a bit more as the a6 also has 8 assignable cc's-in
Astral
PostPosted: Tue Jul 03, 2012 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got, that makes since. Thanks again Sunny!
